Why can't the Evolution be rear wheel bias?
Old Jun 2, 2005 | 01:34 PM
Wave's Avatar
Originally Posted by voidhawk
Choice quote from the paper:
"If an emphasis on cornering performance is required, the front/rear torque-distribution should be established at about 30:70."
"If an emphasis on traction performance and stability is required, the front/rear torque-distribution should be established at 50:50."
"In light of the factors described above, it was determined that the base front/rear ratio should be 50:50 (optimizes running performance and stability) and that directional response should be maximized by control of the center differential differential-limiting action."
The 50/50 split of the Evo is not a limitation, but a conscious design choice by . It gives you the best possible traction, and the ACD moves the split around that base line to achieve better turning response.
Old Jun 2, 2005 | 01:43 PM
evo 8 ya's Avatar
now you can get a different ACD ECU. But I'm not sure if that ACD ECU will work with the USDM 05 evos or not
Old Jun 2, 2005 | 01:48 PM
travestyevo's Avatar
VR4 = 45/55 Hmm... Good to hear. Thanks.
Old Jun 2, 2005 | 02:12 PM
honda-guy's Avatar
get a spool for the center diff and you'll have constant 50/50 split. not good for daily street driving though.
MATT@WORKS
23
Jan 12, 2008 10:51 AM
amstel78
27
Mar 23, 2007 01:53 PM
Stangar
Oct 7, 2005 03:13 PM
i11matticc
Future Lancer / Evo Models
11
Mar 29, 2005 04:33 PM
GDB
16
Jan 3, 2005 12:02 PM
