help radio/clock/dome lights dont work
Old Jun 1, 2005 | 08:21 PM
Evoisdream's Avatar
hey guys just got back tonight to find out that my clock radio and dome lights do not work....... i figure its a fuse but i checked my radio fuse and its fine? anyone have any ideas car starts fine runs awsome so i have no idea?
any help would b awsome thanks!
evoisdream
Old Jun 1, 2005 | 08:34 PM
mobounce's Avatar
loose or jarred wires?
Old Jun 1, 2005 | 08:59 PM
Turbolover's Avatar
2 ?'s
1-does ur keyless entry alarm work?
2-do u have a turbo timer hooked up?
Old Jun 1, 2005 | 09:51 PM
Evoisdream's Avatar
have a tt hooked up but the car has been the same for like 8 months and nothing like this has happend..... nothing was changed recently i think all the wires are fine unless thier is like one main one...
the keyless entry seems to work but goes in and out i beleave one time it worked and one time it didnt
Old Jun 1, 2005 | 10:32 PM
Evoisdream's Avatar
ok my keyless entry also doesnt work i just tried it and it doesnt
Old Jun 1, 2005 | 10:38 PM
GREDDY's Avatar
Did you install a new stereo recently? I would check all the fuses and not just the stereo fuse. On such a new car, you shouldn't have wiring issues, should be a bad fuse. Check for the dome light fuse. Hows your dash board lights, do they work when you turn on your headlights?
Old Jun 1, 2005 | 10:43 PM
evo81's Avatar
your 10amp fuse went out.should be one of the red ones in the yellow part of the ecu.i've have this happen to me once also.
Old Jun 1, 2005 | 10:45 PM
lookslikeanevo's Avatar
^ ding ding ding
tell em what he has won bob!
Old Jun 1, 2005 | 10:57 PM
Evoisdream's Avatar
just figured that out by SEARCHING! lol im a NOOB hahah sorry guys i was not home and didnt have acess to a comp longer then like 5 min so i made a post my bad thanks for the help ill fix it 2marrow
Old Jun 2, 2005 | 04:15 AM
SLW EVO's Avatar
hehe, simple fuse problem.. knew it right when i read the first post.. haha
Old Jun 2, 2005 | 11:09 AM
Evoisdream's Avatar
sure enough both fuses in the yellow casing were blown
Old Jun 2, 2005 | 11:13 AM
SterlingEvo's Avatar
Along with replacing the fuses you might want to check the whole wire if you can. They may have blown out because an aftermarket wire was crossed or has somehow grounded out, and if so, they'll probably blow again...
Old Jun 2, 2005 | 11:28 AM
sirloin1219's Avatar
cant' take it to the dealer warranty's void. you were not under "normal" driving circumstances. =/
Old Jul 29, 2005 | 07:30 PM
NITROHEAD's Avatar
Just wanted to sat thanks for the info. I looked all day for the fuse but never looked right next to the ecu. THANKS!!!!
johnd651
Lancer Troubleshooting
Dec 19, 2021 08:22 AM
jzapatajr
17
Jun 2, 2020 06:44 PM
elmark44
Jul 13, 2011 03:27 PM
BornSinner
Nov 1, 2007 09:27 AM
peelslancer
Apr 23, 2006 10:02 PM
