Highest HP on a stock longblock?
Old Jun 5, 2005 | 11:21 AM
nolimits1320's Avatar
Originally Posted by Jasil
Nolimits, I talked to 2 vendors and both had about the same advice. With ARP's the stock block is good for 450-500awhp with no detonation.
A long block is different than a short block. The "block" or short block is no doubt capable of that power, but to actually produce it the long block (head included) is usually modified (head studs is a modification). I haven't seen anyone produce those #'s on an unmodified long block, and it wouldn't make much sense to try.
Old Jun 5, 2005 | 12:22 PM
Jasil's Avatar
Originally Posted by VTECH8TR
WHOA. You are a Team NABR member and Don't Know how to use the SEARCH feature .
I see your a NABR member condescending like most on the board, but a great wealth of knowledge the NABR board is.
Old Jun 8, 2005 | 11:24 AM
evodave's Avatar
From: driving the 10 second beast in ohio or running lightmods.net
Originally Posted by evoviiiyou
I know evodave is up there with his Switzer tune!
HECK YEAH
I got 489 awhp on 93 octane and 50/50 alky /water injection....i could have got tons more but i am not sure how far over 600 crank hp a stock motor can go with only $80 head bolts and some cams.....lol
Thanks again slickmotorsports for the great craftsmanship and turbo setup and switzer performance for their awesome tuning and dyno!
Dave
Old Jun 8, 2005 | 11:44 AM
GPTourer's Avatar
I think I know what your are getting at, but it is still a bit misleading. Block and short block are not interchangeable. A bare Evo block may be capable of 1000+ but when you say stock short block you mean stock pistons, crank, and rods. I pretty much accept the fact that it won't be stock long block to get those 450whp+ plus numbers because I know they'll use cams, and then maybe cam gears, bigger valves.
Old Jun 8, 2005 | 07:49 PM
evodave's Avatar
not everyone....the ONLY mods done to my motor internally are head bolts (coulda used stock ones and got away with it for a while but why...its $80 and cheap insurance ) and cams...shoot i never even had the head or oil pan off the car...lol
Old Jul 21, 2005 | 09:40 PM
evodave's Avatar
https://www.evolutionm.net/forums/sh...ickmotorsports
Old Jul 21, 2005 | 09:52 PM
Jakeg97's Avatar
Originally Posted by 3000ways
Dude, the search MUTHERF*CKIN' button is your friend!!!!!! Ever since you signed up on this forum, you just been a negative posting troll. Go back to your Mustangs!!!!!!
lol = https://www.evolutionm.net/forums/search.php?
Old Jul 21, 2005 | 10:02 PM
DragNRacing's Avatar
The short block can put down some serious numbers. Al just put down 744whp on his stock bottom end althought the head is modified and he is using head studs also. I was impressed that the EVO bottom end can hold up to such high numbers where even a 1G DSM with big rods is typically only good for around 500whp.
Old Jul 21, 2005 | 10:09 PM
USP45's Avatar
You are joking right? Al's stock bottom end using the Pauter rods, Ross (I think) pistons, and no balance shafts, you mean that stock bottom end? Unless Al has another Evo hidden somewhere making 744whp, then I do believe that his bottom end is very built.
Old Jul 21, 2005 | 10:10 PM
evodave's Avatar
the most i have heard is 558 awhp that i just laid down.... Al's is def. built
Old Jul 21, 2005 | 10:24 PM
I remembered reading stock so I did a little digging and does have pistons.
Here is exactly what it does have per his post...
"Its a 100% stock original bore block with drop in stock bore Pruven Pistons, balance shafts removed and stock crank."
Dam* pain killers
Old Jul 21, 2005 | 10:29 PM
TrinaBabe's Avatar
Like they all said. The motor will hold over 500 without modification. I have head studs (Not bolts) as well to ensure no leaking of the headgasket but the actually motor holds it fine every day. I will run it at 30 psi shortly so we will see how it does daily at around 550-575 daily. Im sure Cosmo was pushing around 550-580 when he had his stock block. Ran a 10.8 at 128 perfectly stock motor. I plan to do the same.
Old Jul 21, 2005 | 10:31 PM
and I can't wait to see it
Old Jul 22, 2005 | 03:20 AM
4cefedgst's Avatar
Originally Posted by 94AWDcoupe
The evo block is capable of more a bit more than dsm 7 bolt due to the pistons being a good bit lighter. The rods, crank, and block are identical spec.
Not true. The rods in the 7bolt DSM look like the size of rods out of a b16, but they are very strong. The rods in the EVO are forged and so is the crank.
Duby
Mar 11, 2017 10:08 PM
TURBO_S2K
32
Dec 26, 2013 01:18 PM
LGshow19
Apr 26, 2013 12:32 PM
PedroMartinez
16
Jul 1, 2007 06:45 PM
stephenz
16
Jun 27, 2007 10:26 AM
