Need help with my Greddy BOV type s
Old Jun 6, 2005 | 03:43 PM
TurboXtreme's Avatar
Ok my car bogs when i try to go faster i cant even step on the pedal all the way cause it will choke.. its like im flooring it and it chokes and stops then keeps going and chokes..
I looked at my BOV and there are 3 connections on it, isnt there soposed to be four... let me put up a pic
now is the red circle part soposed to be open like that or no?
Someone please clarify this for me thanks
Old Jun 6, 2005 | 03:57 PM
Sackett's Avatar
RRE has their smaller vent recirculating into the adapter plate i think..
you can see it on this pic...
There is another tuning website that has a Type-S settings guide, but i cant find it at the moment. it tells you under which conditions they recommend plugging in that smaller port. someone copied it onto this forum somewhere too, do a search for greddy bov and you'll find it in one of the threads....
Old Jun 6, 2005 | 04:02 PM
ya mine is def not like that.. not even close lol.. i dont know which thread has it can anyone else help out though
Old Jun 6, 2005 | 04:05 PM
Sackett's Avatar
http://www.evomoto.com/tech_info.php...3_10&tech_id=6
http://www.evomoto.com/tech_info.php?tPath=1&tech_id=7
Old Jun 6, 2005 | 04:07 PM
Sackett's Avatar
this seems relevant: "Second, if the single spring mod is not done, the valve should have the lower vacuum port connected to a source still pressurized after the throttle plate closes (IC pipes) and still have a very light adjustment to allow for the easiest valve actuation possible."
Old Jun 6, 2005 | 04:10 PM
Ok well now i believe it isnt installed right.. it might be VTA.. cause it does almost stall out when i try to stop and i take it off gear... something needs to be connected thats not connected is that port that i showed in the pic soposed to be connected to something?
Old Jun 6, 2005 | 04:16 PM
ddubb's Avatar
If you do the single spring mod and are recirc, you don't have to connect the smaller port. I am running the single spring mod and have my set up like yours and have no problems idling or no stalling issues at all.
Old Jun 6, 2005 | 08:55 PM
ya your right.. ive come to the conclusion that its the fuel injectors.. they cant handle the 22 psi.. its too much stress. What it does is it cuts off the fuel almost kinda like the car shuts off and then starts back up again.. kinda like the brain shuts off then restarts instantly.. but thats the main thing.. i guess i need to upgrade the fuel injectors and such..
Does anyone with experiance know anything about this?
Old Jun 6, 2005 | 09:27 PM
theblue's Avatar
it your car tuned to run a BOV? if you're running stock ecu then it's looking for air that gets lost... makes the car run rich as **** betweens shifts.. not a very good idea. running 22psi without headstuds is also asking for trouble.
Old Jun 6, 2005 | 10:46 PM
4TUN8's Avatar
Old Jun 7, 2005 | 01:15 AM
ct9a gsr's Avatar
The stock injectors are more than big enough to handle over 24psi on pump gas... however, the stock ecu's programmed to enable fuel cut @ 24psi. You do not need bigger injectors.
Old Jun 7, 2005 | 01:25 AM
feautoevo's Avatar
sounds to me like you have a hose not connected if u loose an intercooler hose it will give the same conditions u describe try running the car and revving it up to make boost while you listen under the hood.... and do the single spring mod and re-sirculate it...
Old Jun 7, 2005 | 03:41 PM
Im going to take it to my evo specialist person i know hopefully he can help me resolve the problem.. thanks again guys
Old Jun 7, 2005 | 05:59 PM
theblue's Avatar
ok... but if this is the guy who recommended 22psi and a BOV without tuning then you might want to go anywhere else.
Old Jun 7, 2005 | 06:28 PM
Jakeg97's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=113527
