HKS Dynochart of USDM Evo 8
Old Feb 19, 2003 | 04:22 PM
  #91
Ben's Avatar
Ben
Originally posted by Max Rebo
Isn't drivetrain loss the same regardless of engine output?
That's what my arguement was, that it's more accurate to look at a set HP loss. But we've been through all of this and there is no chance of getting either side to budge so just do a search for the last dyno thread.
Old Feb 19, 2003 | 04:55 PM
  #92
MrAWD's Avatar
Originally posted by Ben
The dyno rollers are also being accelerated as a part of the drivetrain. The wheels are basically connected to the rollers just as the layshaft is connected to the gears. That effectively adds the rollers weight into the drivetrain, it's all 1 system. So the inertia or resistance of the rollers has to be added to the resistance of the drivetrain. Torque and HP are being computed by how fast the car accelerates the large mass. The rollers having a relatively large inertia compared to the drivetrain will minimize the effect of the drivetrain on the final #.
For example, I just did a quick google search and on a 2wd dynojet the 2 drums weigh 2700 lbs each. So on a 2wd dynojet a car is accelerating a mass of 5400 lbs + whatever the drivetrain weighs. So the relatively small weight of the drivetrain will have little effect on the final #.
Yes, you are correct about this part. It is all the same system. Dyno wheels are way bigger than the anything else that has to rotate inside the car. That is why you get 240 HP at the dyno wheel and loose 40, 50, or even 60 HP inside the drivetrain.
So, the same way that big heavy dyno wheel gets to measure the power passed on it from the wheels, some of that power goes to the all of the rest of the rotating parts. So, if you spin that big wheel from speed V1 to speed V2 in the time T1 that would give you HP rating of P1. Now if you do the same thing from V1 to V2 in shorter time that we call T2 (remember T1 is bigger than T2), you will also get bigger number for the power P2 compared to the P1. That was all happening while trying to spin a big mass of M1 from the speed V1 to V2. That is how you get your HP readings.
Now move inside the trainy and check one of the gears that has to spin during the same process. This time your gear has a mass of M2 which is much smaller that the dyno wheel mass that was M1. To accelerate that small gear with the mass of M2 from the speed V1 to V2 in a time T1, you will need Pp1 amount of power. Now, if you have more power and spin it in time T2 (shorter than T1 in the first case), you will also have to spend more power on that small wheel and if you would measure it, you would get Pp2.
By adding all of those power numbers from P1 over the Pp1 and the rest of them (Pa1 + Pb1 + Pc1 + ... + Pp1 + ... = SP1), you will get total power number for the case one. In the second case you will have P2 and SP2 (sum of the Px2s). Ratio between those two will stay the same all the time, which will give you your losses.
Fedja
Old Feb 19, 2003 | 05:25 PM
  #93
astondg's Avatar
Originally posted by Speedlimit
Do you use 25% or 15% drive train loss from your last dyno run to answer the question?
Aston
Old Feb 19, 2003 | 05:29 PM
  #94
GPTourer's Avatar
More then likely all the car's tested so far are preproduction test mules and may be a little different from actual production models. Considering the lead times of magazines, all of this stuff we're reading now was done 2-3 months ago, back when we didn't know how much hp it was supposed to have.
Old Feb 19, 2003 | 05:53 PM
  #95
broeli's Avatar
And about the EVO being overated, why did the only mag test so far only get 13.8 in the .25 and 5.1 0-60?
The only test we know for sure done by a magazine, was done at LACR, and I'm assuming it was R&T since they list the same #'s someone posted it ran at LACR. Like we discussed before LACR is 2700ft above sea level and has a crappy surface. Everyone I know with forced induction that runs at LACR generally runs about .5 slower in the 1/4.
Old Feb 19, 2003 | 06:42 PM
  #96
suave3747's Avatar
In reference to the argument about percentage or constant drivetrain loss, look at the amount of power that JoCCe and yelo3 put down in their Evos at the crank, and how much power they have at the wheels. JoCCe puts down something like 650 hp at the crank, and 530 at the wheels. I don't know what yelo3's crank power is, but he puts down 590 at the wheels. Just looking at his mod list, you can tell he has something like 725 or so.
These cars are losing around 18% to the wheels across their drivetrain, which is less than 24% because of mods they did to the drivetrain, such as magnesium wheels, lightweight flywheels, dogboxes and lightweight clutches.
If the constant theory were right, JoCCe would make 530 at the wheels and only 580 or so to the crank, and the same would apply to yelo3.
Old Feb 19, 2003 | 07:13 PM
  #97
Ben's Avatar
Ben
Have they actually had the engine out of the car and HP measured at the crank? If not, then none of those numbers mean anything, they're just estimates.
Old Feb 19, 2003 | 07:16 PM
  #98
Ben's Avatar
Ben
Even the AWD cars? An AWD car should still be able to get a decent launch. Maybe not the best launch, but I doubt it would spin enough to loose .5 seconds. True there's the altitude as well, but that doesn't effect FI cars as bad. So if it really were over 300hp I'd still expect better than 13.8.
Old Feb 19, 2003 | 09:01 PM
  #99
Speedlimit's Avatar
Admin Emeritus
Hi,Well..... this has to be the longest thread I have read in awhile where someone was not called bad name Nicely done gentleman. (and ladies).
Originally posted by Claudius
I'm sure we could come up with something if you insist LOL
Hey Claudius!
Well ......... no use waiting any longer....... preemptive it is. Your an arss!!! LOL
Speedlimit.......
Old Feb 19, 2003 | 09:07 PM
  #100
suave3747's Avatar
"Have they actually had the engine out of the car and HP measured at the crank? If not, then none of those numbers mean anything, they're just estimates. "
I should say brake horsepower then. I'm sure that they've both had their engines out, but I can't say whether they've actually tested hp at the crank when the engines were out. Nevertheless, even with brake horsepower you can tell about what crank hp would be.
And their losses are % based to their wheel outputs.
If the constant theory were right, then the 1000+ hp skylines and supras would only be losing 50 hp to the wheels from the crank, and i've never seen one of those cars with that little drivetrain loss.
Old Feb 20, 2003 | 01:01 AM
  #101
paradox's Avatar
why is everyone saying BRAKE horsepower?
maybe they had a few too many
Old Feb 20, 2003 | 02:22 AM
  #102
Ev0six's Avatar
thats what bhp stands for.
Old Feb 20, 2003 | 02:40 AM
  #103
JT-KGY's Avatar
wow.. awesome numbers!!
Old Feb 20, 2003 | 02:43 AM
  #104
Yojimbo's Avatar
Brake Horsepower (bhp)
(various explanations from various places)
- the amount of horsepower the engine actually delivers after internal friction and parasitic loses are taken into account.
- the vehicle’s horsepower measured where the power is delivered (for example, at the rear axle of a truck tractor). Shaft horsepower is the power measured at the engine itself, before any losses from the clutch or differential occur.
- the rate at which an engine does work, expressed in horsepower. It is measured by the resistance of an applied brake.
- Dynamometers measure torque by use of a brake. Brake torque is simply a measurement of how much resistance is needed to hold the engine at a steady rate of speed. This is commonly referred to as a step test, usually taken in 250 rpm increments. Brake Horsepower (BHP) is then figured using this formula, HP = (rpm × Torque) ÷ 5252 . The problem with brake torque is that it is not effected a measurable amount by the inertia of the engines rotating and reciprocating parts. For an acceleration engine, there is a better way.
- etc.
Old Feb 24, 2003 | 01:40 AM
  #105
paradox's Avatar
I thought bhp stood for base horsepower
