Evo on a 2 wheel dyno?
Old Jun 7, 2005 | 10:56 PM
PunoEvo1337's Avatar
is it possible and how would you lock either the front wheels or back wheels or is either side lifted
Old Jun 7, 2005 | 11:04 PM
Tim@AMSperformance's Avatar
It is possible you have to modify the centerdiff in the t-case. Probably not something you would want to do because it is permanent due to welding
Old Jun 7, 2005 | 11:06 PM
evo1919's Avatar
lock the wheels of an AWD car???
why you nned to do that?
Old Jun 7, 2005 | 11:10 PM
i thought i read something about being able to do that on the older evo models when awd dynos were not as prevalent as they are today (not that prevalent IMO), i only was wondering this because i just got relocated to ky and i dont know of any awd dynos here... they have one near st louis but its hard to find time to get back there
Old Jun 8, 2005 | 01:49 AM
plokivos's Avatar
you somehow disable the rear wheel. I've seen it done before.
i think buschur racing had 2 wheel dyno...
Old Jun 8, 2005 | 01:52 AM
evofan@scorp's's Avatar
Easy, jack the car up and disconnect the driveshaft going to the rear differential. Make sure you mark it though before you take it out....there may be a chance of an out of balance shaft if installed wrong.
Old Jun 8, 2005 | 05:02 AM
jjm4life's Avatar
what he said. people on the jeep boards have done this before except they disconnect the front driveshaft. i would leave it alone and try to find an awd dyno closer or just make the trip.
Old Jun 8, 2005 | 05:33 AM
ShapeGSX's Avatar
The center diff isn't in the transfer case. It is in the transmission.
And you can't just disconnect the driveshaft to make an Evo FWD. You will burn up your center viscous coupler (if so equipped).
Old Jun 8, 2005 | 05:43 AM
eve-slow's Avatar
AMS converts EVO's to FWD for dyno testing (don't exactly how though).
Old Jun 8, 2005 | 05:44 AM
AznX TL's Avatar
you can do it if you look in the manual it says if you lift the hand brake to a certain angle you can make it into fwd o yea u also need ACD so only 2005s can do it
Old Jun 8, 2005 | 06:00 AM
DCSilvrEvo's Avatar
Right. You cant just disconnect the driveshaft because the TCase fluid will come out.
You burn up the Viscous if you do it the other way around.
Old Jun 8, 2005 | 06:14 AM
celerilux's Avatar
I heard or read somewhere that there was a simple disconnection of a wire to make the Skyline a RWD car. Is that true?
Old Jun 8, 2005 | 03:57 PM
Jakeg97's Avatar
why 2 wheel dyno?
Old Jun 8, 2005 | 04:36 PM
bigjhoney's Avatar
That true for a skyline, not an evo. And the other persons post about the e-brake, wouldnt that just lock the back brakes up?
Old Jun 8, 2005 | 05:29 PM
rezo's Avatar
I believe pulling the e-brake disconnects the center diff... I know it does in rally cars (so you dont stall the engine when you lock up the rears to slide around a turn) and I remember reading something about ACD equipped Evos having the same thing, but I'm not 100% positive on that one gonna look to see if I can find the place I read that.
edit: yeah I found it in my owner's manual, says that while the vehicle is in motion, if you pull the e-brake it will disconnect the center differential allowing the rears to lock up... don't know if this allows you to run an evo on a 2WD dyno though
