Hallman Boost PSI Problem
Old Jun 13, 2005 | 11:02 AM
BlueEvo04's Avatar
Hi everyone,
I just bought a Hallman lancer evo short kit, my mods are hks exhaust, tanabe dp, megan hi flow cat, greddy S bov, Helix IC Pipe kit, and I'm not gonna upgrade on the performance. What psi should I leave it on if I have stock turbo, stock fuel injectors and etc. I heard the engine will blow if psi goes over like 25 something like that. Any info/help would be highly appreciated.
Old Jun 13, 2005 | 11:07 AM
krafty's Avatar
19-20 with no tune, 21 with a tune, or flash.
Old Jun 13, 2005 | 11:08 AM
advancEvo27's Avatar
The average amount of boost every one runs is around 20 give or take a lb
Warrtalon's Avatar
Originally Posted by BlueEvo04
Hi everyone,
I don't see the problem...what is it?
Are you saying that you installed an MBC, but that you are "not gonna upgrade on the performance"? If so, then set it at 18-19psi, which is stock for 03-04s. If you want to make good use of your MBC, then set it at 20-21 on 93oct.
Old Jun 13, 2005 | 11:10 AM
Nez136's Avatar
this is my 2nd evo and i always left my settings at 21.5 psi, it always ran safe
Old Jun 13, 2005 | 11:17 AM
Thegame's Avatar
I always run 20 psi in 4th and 5th. 1st and 2nd are a little lower, that's just the nature of a MBC as opposed to a EBC.
Old Jun 13, 2005 | 11:23 AM
_007's Avatar
Where should the PSI be in 3rd, 4th and 5th gear. I got flashed by AL. Please let me know where should I be at when I fill it with race gas.
Old Jun 13, 2005 | 11:27 AM
Warrtalon's Avatar
What do you mean? Set it where you want it...
Old Jun 13, 2005 | 11:30 AM
_007's Avatar
What I am trying to say. My boost spikes to 23 and then stais at 20 in 3rd gear. In 4th it just stais at 20. Is that ok?
Old Jun 13, 2005 | 11:31 AM
Kronik's Avatar
Yes, that's fine.
Old Jun 13, 2005 | 11:34 AM
_007's Avatar
Thank You guys...
Old Jun 13, 2005 | 01:27 PM
BlueEvo04's Avatar
So leave it around 19 - 20 with no tune right? Thanks alot for infos
