View Poll Results: Tire wear, front or rear faster? Or is it Even?
Front faster
25
56.82%
Rear faster
6.82%
Even wear (rotate tires often)
20.45%
Even wear (seldom rotate tires)
15.91%
Voters: 44. You may not vote on this poll
How is your tire wear on the Advans?
Old Jun 17, 2005 | 09:07 AM
alan678's Avatar
Unhappy
WOW...my tires only lasted about 6-7k miles before i replaced them...DAILY DRIVEN 6-7k miles at that...the insides were to the wire basically...i was told by the delearship that my alignment was off when i first took it in for them to look at 2k miles, but their alignment didnt fix it...new tires have 3k on them now and are holding up like champs (maybe because they have a 400 treadwear rating )
Old Jun 17, 2005 | 09:11 AM
rallytrack's Avatar
I got about 15,000 out of mine.
Old Jun 17, 2005 | 09:24 AM
sabastian458's Avatar
at about 6k started showing definate signs of inside wear, at 15k had to be replaced, but then again it had alignment issuse. so it would have worn faster than most people's
Old Jun 17, 2005 | 09:29 AM
Evoryder's Avatar
more on front... 10k mileage
Old Jun 17, 2005 | 09:36 AM
Darkstar1's Avatar
Mine lasted 15,500 miles before I had cord showing on the inside of the front tires. I have been running at -1.8 front, -1.3 rear, 0 toe all around. I switched to Kumho Ecsta MX tires and am very impressed with the price/performance ratio. The sidewall is a little softer than the Advans, but they have awesome grip, wet or dry.
Old Jun 17, 2005 | 09:44 AM
sleet's Avatar
Mine only lasted 5k miles, pissed me off so much...
Old Jun 17, 2005 | 10:00 AM
RAWMR's Avatar
7.5K and the tires look pretty new. Never rotated and I'm not very easy on them either. Maybe I got lucky with the factory alignment?
RAW
Old Jun 17, 2005 | 10:06 AM
JESSEFREITAS's Avatar
9k miles had belts showing
Old Jun 17, 2005 | 10:45 AM
webguy330i's Avatar
I don't rotate my tires. I feel the tires will wear to that particular corner's 'characteristics' and that's the best spot for it.
As for wear, I get about 10-15k out of each set, going on my 4th in another week or so. Fronts wear almost 2x faster than the backs, usually with more wear on the inside/outside tread blocks of each front tire.
The rears wear pretty evenly, just a little more neg camber wear on the insides.
For the grip they offer, I think they do pretty damn well.
Old Jun 17, 2005 | 10:59 AM
MEVO's Avatar
Factory alignment tends to be junk on Evos. I had the dealer realign mine at 7k for free. Inside of fronts wore quicker, I'm at 18k, pretty bad now, but good enough for the drags.
Old Jun 17, 2005 | 11:03 AM
James's Avatar
when i first bought my car in 03 the stock Advans didn't last but 8k miles, lol i learned how to power slide a so i would do it any chance i could. this doesn't help your tires life.
but they wear out evenly
james
Old Jun 17, 2005 | 01:06 PM
webguy330i's Avatar
james
Old Jun 17, 2005 | 01:09 PM
Ludikraut's Avatar
I have 18K miles on my original Advans and could have probably gotten ~24K out of them ... unfortunatley my Evo seems to have developed considerable toe-in in the front and has managed to almost nuke two tires before I noticed. Hopefully I'll still get about another 3K out of the current rotation. However as soon as my new wheels arrive, I will be running BFG KD's as my street tires and I will dedicate the stock rims and Advans as track only tires.
l8r)
Old Jun 17, 2005 | 01:17 PM
DaWorstPlaya's Avatar
The factory manual states that the EVO should be set to 0.8 deg toe-in (I think, number might be larger) in the rear. Combine that with negative camber and that is what is eating the insides of your rears so quickly .... you can change the toe to 0 deg front and rear and not have any significant change in handling, toe-in in the rear makes the rear more stable during cornering .... so factory settings are designed to eat your tires ... SAVAGES!!!
Old Jun 17, 2005 | 01:43 PM
Ludikraut's Avatar
^^ crap, I did not realize that. I need to go to an alignment shop ASAP!! Thanks for the info.
l8r)
