High speed braking, rear end wiggle....
Old Jun 19, 2005 | 04:06 PM
westchester evo's Avatar
Any one know why braking at high speed in a stright line I have a rear end wiggle??
Old Jun 19, 2005 | 04:12 PM
Kwman's Avatar
Weight transfer. Weight transfer induced oversteer can be dangerous at high speed if your not comfortable using it. Wingless will make the effect even greater.
Old Jun 19, 2005 | 04:34 PM
I put in a set of Omnipower coilovers and now I notice the wiggle. Do spring rates have an affect ?????
Old Jun 19, 2005 | 04:36 PM
DCSilvrEvo's Avatar
Most cars are like that. ESPECIALLY FRONT ENGINE CARS! All my cars do. Basically you just have to keep very still and steer as you need. If the back comes too loose then GET OFF THE DAMN BRAKE a little bit
Old Jun 19, 2005 | 04:51 PM
plokivos's Avatar
high fast are you going?
Old Jun 19, 2005 | 04:52 PM
Well after road racing the car for 2 years with the stock springs It never had the problem,,,
Old Jun 19, 2005 | 04:59 PM
plokivos's Avatar
i don't have that problem either.
I do have brake steer over-correct on the corner. but that's normal.
Old Jun 19, 2005 | 05:00 PM
120 mph and above.....
Old Jun 19, 2005 | 05:03 PM
SIC SIK SIX's Avatar
when you brake, most of the weight goes to the front
Old Jun 19, 2005 | 05:04 PM
Again... Untill putting in coilovers I never had the problem.
Old Jun 19, 2005 | 05:07 PM
plokivos's Avatar
it's your coilovers. they're not weigh balanced.
I do over 140mph heavy braking, nothing happens.
FWD based Awd is a lot more stable at high speed on brake and turns than AWD or RWD based AWD.
Old Jun 19, 2005 | 05:09 PM
DCSilvrEvo's Avatar
But ur probally braking in a straight line. if your Turning at all the BACK will swing.
Old Jun 19, 2005 | 05:25 PM
03BlackEVO's Avatar
if you are doing triple digit speeds you should prolly just tap the brakes multiple times get it under 90ish and then apply the brake..
Old Jun 19, 2005 | 05:28 PM
Yea, try that on a race track and see what happens.....
Old Jun 19, 2005 | 05:30 PM
DCSilvrEvo's Avatar
LMAO RIGHT. That will = TOTAL LOSS.
