Cant decide which cams? Daily driver post your dynos and what duration you have
Originally Posted by WrX Kila
264/272 best of both worlds. 272 will not shine with the stock turbo.
BTW Mustang Dyno...
I would do some reading on lift and duration and then choose a cam that will fit the bill for those areas, and also decide on if you're going to upgrade the turbo or anything else in the future. The smallest I would do is 272's if you're ever going to upgrade.
lol i would agree that alot has changed in 5 years. i wouldnt go any smaller than 272's either. im planning on upgrading to a pte6262 on the stock block for now. i was thinking of running the 280's (int/exh) with the supertech dual spring and retainer kit, and upgrade the valves as well. that way i could leave the head alone if i ever went with a built shortblock and wanted to make more power.
Go with gsc s1. They have proven to make great midrange power for the stock turbo and have stock-like idle and drivability. I have hks 272s and the idle is kinda rough (but sounds pretty good). However, for some of u saying that 272s dont make power on the stock turbo, Im not sure where you're getting your info from. I gained 40whp switching from stock cams to hks 272 and stock IC and piping to ETS 3" core and 2.5" piping, without raising boost a bit. More peak tq and less tq taper throughout. S1 should do the trick if u want some power with little to no idle/drivability changes
Runnin dual BC 272's on stock and still idles just fine, it was really near idle. Was quite surprised when I got the car tuned and the first drive back, was expecting it to be much more rough.
