where is the crankshaft positon sensor Plug?
Old Jul 1, 2005 | 01:51 PM
redevo58's Avatar
where is the crankshaft poistiion sensor plug? i'm going to do a compression test. from the pic of the manual posted here i cant tell what the plug is located?
Old Jul 1, 2005 | 02:09 PM
bolsen's Avatar
oops sorry, read it as cam angle.. lol
Old Jul 1, 2005 | 03:38 PM
propellerhead's Avatar
The crank angle sensor is #15 in this diagram.
Old Jul 1, 2005 | 03:49 PM
redevo58's Avatar
Damn thats a nice diagram, do you know where the actual wire connection is, thats the pic that i need. or just the area and description of it.
Old Jul 1, 2005 | 04:04 PM
If you're standing at the front of the car with the hood open, look down at the top of the oil cap. At approximately the 10 o'clock position from the oil cap just behind the valve cover you should see a triangular plug with rounded corners. The wiring harness plugs into the crank sensor plug. The crank sensor wire runs underneath the sparkplug cover towards the front of the motor.
Old Jul 1, 2005 | 04:17 PM
redevo58's Avatar
Found it thanks.
