Exhaust install
Old Jul 8, 2005 | 07:25 PM
WeightlessEvo's Avatar
Exhaust install
Hey guys, have the WORKS dp and their HFC sitting in my room along with the HKS Hi Power Carbon/Ti Catback on its way. I am going to get it all installed as soon as it comes in and was wondering is there anything as far as installation problems I should be aware of with this setup or will it clear the tie bars and oil pan, etc. ? Thanks, appreciate it.
Old Jul 8, 2005 | 07:39 PM
byebyeV8's Avatar
The WORKS dp fits perfectly. I have the full WORKS turbo back w/hfc and abm and it clears the croxx plate without a problem. WORKS says it moves up and in(away from the bars) as it heat cycles a couple of times but mine fit fine from the get go.
Old Jul 8, 2005 | 09:58 PM
s2krn's Avatar
Save yourself some time and headache... loosen the cross braces underneath and swing them out of the way. It takes so much time off. I would have been done an hour earlier if i had just done that. THey are easy to loosen and easy to retighten.
Old Jul 11, 2005 | 04:00 PM
kyJelly's Avatar
swing out cross braces, get a buddy, some beer, and a lift of sorts and make sure you thread the bolts correctly for the dp
