how do you get bigger things through the fire wall
ok here is the problem im having, im trying to get a o2 sensor plug through the fire wall and i dont see a place for it to pass through. i realy dont want to have to drill a hole that big. does any one know a place that would be large enough to get this thing through? its about 1" x 3/4". sorry the post is so jumbled, im trying to do it right now and im realy frustarted ><.
Are you trying to get the plug to go from inside car to in the engine bay?
I have no idea what your plug looks like, but I assume it has a cable/wire attached? Why don't you place the plug in the engine and try to feed the cable/wire from the engine bay to the inside of the car. There's a rubber grommet located behind the passenger side strut mount. You can pop that plug, drill a hole in the plug, and feed the sensor's cable/wire that way.
Dude, cut the wire and run it through an existing hole, then splice it back together. If you can't find a hold to poke it through than just drill a small hole through the firewall.
I ran mine through the hole underneath the fron passenger seat. I had to cut the grommet, but I re-sealed it with black RTV. This is the same hole where the factory O2 runs through.
No splicing required.
Originally Posted by plokivos
yeh, if you could do it, I wouldn't cut that line. They're fairely sensitive to even a small change.
Example: Stock "high quality" sensors vs. the cheapo generic brand ones you can get a Pep Boys
Both will run your car just fine, but it's unlikely that their calibration is 100% dead on. Worst case is your fuel economy is a little worse than it should be.
i was able to go through the fender area. theres an opening from under the hood by the intake. i sent the wires through there. then pulled off the fender inner liner above the tire to get access. then pushed it through a grommet that drops right into the cabin.
Yea that will work, or you can take out the gauge cluster and drill a hole right behind there, insert any type of grommet (rubber, plastic) and run your wires through there. The key is to make it big enough that you can run other wires through there later on so you dont have to make more holes. If you put the grommet up that high in the firewall, your chances of water getting in are pretty slim..
Originally Posted by o4whtevors
well i went ahaed and cut the wire and spliced it back together. thanks for the replies guys, i was at my witts end for a min there
