EVO going in for major service...
Old Jul 13, 2005 | 08:19 PM
MitsuJoe's Avatar
My EVO is going in for a tranny tear down and rebuild of all TSB's and grinding caused from 2nd,4th, and 5th gears. I am on the original clutch so it will be mightey interesting to see what comes out of this service. I am lightly modded and the dealer has not been concerned about my modifications inregards to this issue. I have 33k miles.
My second question is in reagrds to as long as the original warranty is in-tact should Mitsubishi pay for a loaner car while my EVO is in service? Does anyone know. Thanks.
Old Jul 13, 2005 | 08:21 PM
jeffm1999's Avatar
depends on the dealer... when I had my Transfer case replaced under warranty (factory forgot to fill the TC with gear oil ...) they gave me a loaner Kia Optima.... sweet ride Hope they take care of you
Old Jul 14, 2005 | 01:26 AM
deekay247's Avatar
I got a loaner while my car is down. Actually it's being fixed right now and should have it back friday. Getting my second and fifth gear synchro replaced along with the synchronizers. I'm at 33k miles also. Good luck!
Old Jul 14, 2005 | 09:38 AM
BuLocal's Avatar
Let us know if you get the loaner
Old Jul 14, 2005 | 10:25 AM
money pit's Avatar
Good luck with the loaner Joe! I'd offer up my Murano, but I need it to haul the golf clubs!
Old Jul 14, 2005 | 11:29 AM
MitsuJoe's Avatar
I REALLY LIKE THE SIG...nice.
Yeah I wouldn't mind driving a Nissan although I just want to be sure I will be able to drive something.
Old Jul 14, 2005 | 12:13 PM
Thoe99's Avatar
How do you guys grind 5th? Is it from shifting to 5th pretty fast? Or just normal shifting and it doesn't go in? I almost never shift to 5th fast and have never experienced a grind in it. 2nd gear, however....
Old Jul 14, 2005 | 12:21 PM
slt's Avatar
slt
Good Luck. I had the same thing done and they managed to mess it up. It came back leaking Trans fluid and the stickshift now dances when its in first gear. It doesn't grind fifth anymore, though.
Old Jul 14, 2005 | 12:31 PM
UT_Evo's Avatar
The only time I ever have problem is when the car is still way cold... and then it grinds in almost every gear unless I take a good 10 seconds to shift.
Old Jul 14, 2005 | 12:50 PM
MitsuJoe's Avatar
All it takes is one shift that is bad to mess up the 5th gear syncros. I have never really speed shifted my car. I would imagine that would break things. It is all in where you engage the gear. I have notchy/grinding in every gear it just depends on the conditions. I typically get more grinding when I am trying to take it easy in the car. What A PITA. They will fix it right I am sure. This dealership has 2 out of 12 Diamond Star Exclusive mechanics in the country. I am sure they will get the job done right the first time.
I have been told by many that a loaner should be prvodied. I will call MItsu later to find out the real scoop.
