wheel shake when braking on highway
Old Jul 16, 2005 | 07:50 AM
el producto's Avatar
Do i need a tire rotation?? My advans have almost 5000 miles on then
Old Jul 16, 2005 | 07:51 AM
05WhiteEVO8's Avatar
You probably need to get your tires balanced or your rotors turned. It is usually only the front ones that require this (rotors). Hope this helps.
Old Jul 16, 2005 | 08:41 AM
GOKOU's Avatar
Common problem with the EVO. SOme say it's the rotors and some say it's due to the pad transfer. I suggest turning your rotors or skiming it and getting a new set of aftermarket pads with proper bed-in. I recently replace my pads but did not turn my rotors. WHeel still shakes during highway braking. This could be due to the fact that I was not able to do ten 10 60-10mph stops.
Old Jul 16, 2005 | 08:49 AM
03EvoVIII's Avatar
Warped rotors... go get them turned
Old Jul 16, 2005 | 09:29 AM
mdosu's Avatar
yep. Resurface rotors or just replace them...if you were in the market for them anyways, go for slotted.
Old Jul 16, 2005 | 02:52 PM
DragNRacing's Avatar
ditto...sounds like rotors
Old Jul 16, 2005 | 02:58 PM
BensLancer's Avatar
listen to these guys, I was told that it was cause I had 18s on my car instead of the stock 15s which is a load of crap in my opinion!
Old Jul 16, 2005 | 03:15 PM
Wicked05's Avatar
rotors, rotors, rotors.....turn, turn, turn.....wheel shake upon brake pedal pressure is most likely the rotors...
If your wheel was out of balance...it would shake regardless if you had applied brake pressure or not....but usually at certain speeds when the harmonic balance is off..
it's ur rotors dude....
Old Jul 16, 2005 | 03:36 PM
GOKOU's Avatar
Was this from Typical crap from them
Old Jul 16, 2005 | 03:39 PM
mathgeek's Avatar
I had the same problem, and my Evo has under 3000 miles on it. There was a slight vibration in the steering wheel when the brakes were applied. I took it into the dealership yesterday, and they discovered that the pads were defective. They replaced them all and turned the rotors. The warranty covered it all. 5000 miles is too early for you to be having this problem. See what they say.
