5th gear grind??
Old Jul 30, 2005 | 02:27 PM
shivaswrath's Avatar
So this TSB (Syncro+Reverse Idler Gear+Input Shaft Bearing) applies to the 2005 trannies as well??
Old Aug 1, 2005 | 07:59 PM
Daman Wiseman's Avatar
I am having similar problems with my 03. In addition it grinds going into 2nd under hard acceleration and it is starting to grind going into 4th. I have a short shifter and aluminum shifter base bushings and aluminum shift rod bushings. My tranny was grinding going into 2nd before these mods but the others started about 4 weeks after. Could any of these mods be affecting the tranny or does this sound like the TSB you guys are takling about?
Old Aug 1, 2005 | 08:15 PM
Deepseadiver's Avatar
Same with my 04 it grindes when I shift into fifth at high RPM's. I took it in and was told that they would replace it when it happens under "normal" driving conditions. Whats normal for the evo?? What a pain in the azz! I guess I should beat on it until it fails. what do you think?
Old Aug 2, 2005 | 04:56 AM
Redcloud's Avatar
Normal should be anywhere within the redline if you ask me! Mine would only grind above 5.5Krpms and that didn't pose a problem with my dealer.
Daman: The TSBs only mention the reverse and 5th gears but if you have a bad syncro in any gear and are still under warranty have it checked out!
Old Aug 3, 2005 | 06:20 AM
NYREDEVO's Avatar
I took my car in yesterday and they could not replicate the problem. It won't happen unless you shift over 5.5K. The dealer told me he didn't "get on it" -I was like then how would you replicate the noise then....retarts. I'm going to make them come with me in the car today. They were saying they might not warranty the snycros b/c i have a ACT clutch.
Get this though....they installed it. Makes sense huh?
This whole reverse idler gear TsB....would that have anything to do with grinding in reverse?
Mitsubishi needs to learn how to make trannys....
Old Aug 3, 2005 | 06:59 AM
Redcloud's Avatar
"This whole reverse idler gear TsB....would that have anything to do with grinding in reverse?"
Exactly! It was a grind when shifting into reverse followed by a "clunk" for me. I can say that after the repair every thing is cherry!
Old Aug 3, 2005 | 08:10 AM
NYREDEVO's Avatar
Does anyone have a copy of that TSB??
Old Aug 3, 2005 | 08:13 AM
Redcloud's Avatar
I tried to get it but they said no. I'll check my statment to see if there is a TSB ID number or something like that on it when I get home tonight.
Old Aug 3, 2005 | 06:26 PM
WrX Kila's Avatar
Car wont go into reverse. Is it the TSB for reverse idsle thing too? If it is I am taking my car in Tommrow
Old Aug 4, 2005 | 02:54 AM
Redcloud's Avatar
Yes that's it! This is the worst caseso far though!
Old Aug 4, 2005 | 03:21 AM
WrX Kila's Avatar
Well this just happened to me last night. I am going to the dealer with the car. I am over 36k though.
Old Aug 4, 2005 | 05:54 AM
NYREDEVO's Avatar
Powertrain is 60K - Dont let them Bulls#@t you!
Old Aug 9, 2005 | 12:49 PM
WrX Kila's Avatar
They are going to fix it. MMC Not a bunch of scum bags after all.
Old Aug 10, 2005 | 09:26 AM
NYREDEVO's Avatar
What dealer did you go to?
Old Aug 17, 2005 | 08:58 PM
Mr.zo6's Avatar
number
