the most accurate type of dyno
Old Aug 4, 2005 | 08:49 AM
  #31
gonzo's Avatar
Originally Posted by SevenFour
A DYNO IS A TUNING DEVICE NOT AN INTERCOCK ENLARGER.
Old Aug 4, 2005 | 10:10 AM
  #32
Dyno4mance's Avatar
DYNOS ARE TUNING DEVICES, AND SHOULD NEVER BE USED TO SHOW HOW MUCH REAL WORLD POWER THE MOTOR IS MAKING.
The only thing dynos are good for are back to back comparisons of different tunes (baseline run, later that day tuned run)
Dynos are used to show gains and losses from tuning, not to tell you how much power you're making. If you want to know that goto an engine dyno.
THAT SAID, DynoJet dynos are the most consistant dyno location to location due to the fact that the dyno operator is entering minimal parameters. For example if you dyno on a DynoJet 424x in NY and then one in Florida, the SAE corrected numbers should be within 2%. This is the reason that most people, my self included, prefer DynoJet numbers. (Although, there are ways to alter the files to make it appear to make more power without any of the displayed parameters being changed)
Mustangs, DynoDynamics, SuperFlow all require the dyno operator to factor in a correction factor. This correction factor can either make the WHP output very high or very low. When on these dynos most of the operators enter in correction factors to attempt to get their machines to read close to a local dyno jet. Although I have seen "shadier" shops use this input ability to inflate dyno results for cars they have tuned/shop setups to drum up business.
As far as DynoDynamic's consistancy, the BEST I've ever personally seen for a DD dyno is 3% variation back to back pulls. I think that's about average, certainly not the "best" in terms of consistancy. DD does offer a massive ammount of logging information standard (items like AFR are optional w/ DynoJets) which is very nice. I've never liked the software though; the power curves don't scale well, the general interface is too dated and the printouts are sub par. Overall, I'm not a huge fan of DD, although I do very much so like their dyno design. If they update their software and adopt a un-alterable weather station w/ set parameters for user input to avoid number inflation I would highly reccomend a DD system. I know a lot of guys sing the high praises of the DynoDynamics because they're so sensitive due to the low weight of it's rollers, but I've never liked the extreme dips and peaks it ends up reading.
Overall, I think it's an excellent Dyno with ****TY software.
Mustang and DynoJet's WinPEP 7, are by far the best "looking" dyno readouts.
As to what dyno is best for tuning, at this point the "big 3" DD, DynoJet and Mustang all offer variable load so they all can be used for partial throttle and WOT tuning. Mustangs I believe use a water brake system (correct me if I'm wrong) like the old Clayton dynos; DynoJet uses I believe a similar system to the DynoDynamics for load adjustment.
But the Short and Sweet of it: Use 1 dyno and 1 dyno only to tune your car. If you want to compare setups to another car, you MUST use the exact same dyno they used to get a truly ACCURATE comparison. A DYNO IS A TUNING DEVICE NOT AN INTERCOCK ENLARGER.
So wrong on so many levels it would be impossible to even start to respond
Where do you live?...If you are not too far away you need to come by the shop I will be more than happy to demonstrate to you that the points that you raise are simply not true....I am all about education
My 2c
Old Aug 4, 2005 | 10:13 AM
  #33
Karash's Avatar
The Dyno is a tool to use *before* you go to the track to find out how fast your car actually is.
Old Aug 4, 2005 | 11:32 AM
  #34
SloRice's Avatar
I’m not going to get into the “who is better than who” argument because I do it every day and it’s not worth my time. But I am going to defend my product.
Dustin@Vishnu – Please think before you post. I have attached a log of what our dyno reads during a run. I know my counting skills are limited, but I’m pretty sure there are more than 8 data points.
Mustang’s dynos offer real time monitoring of up to 8 different channels – RPM, HP, TQ, AFR, Boost Pressure, EGT, Oil and Coolant Temp, etc. All of which is user definable. As far as consistency, Mustang’s are one of the most consistent units out there. I have access to logs of over 50+ runs on my friends Eclipse GST with the BR475 kit to prove it.
Unfortunately, all dynos have the ability to be “modified” to read whatever the shop wants. There is just too much open source code in the software of the systems to not have this happen. Hopefully most shops are honest enough to give real numbers and not BS.
Everyone is on the DD band wagon because its resolution is so great. In all actuality, it’s the other way around. The data is so filtered that you’ll be able to see those 1 or 2 horsepower increases. This is also true for the Dynapaks. It’s a known fact that a motor does not have the ability to make exactly (for example) 200HP at WOT at 4000RPM during a steady state test for an extended period of time. There are to many variables on a chassis dyno for this to happen – i.e. air intake temperature, air velocity, air volume, A/F ratio, temperature of the oil, temperature of the coolant, frictions in the engine and drivetrain, etc, etc, etc – you see where I’m going with this. Our system reads what it reads and spits out the raw information to you. That’s why when you do a steady state test on our unit, it will fluctuate 4-6 HP all the time. IT’S ALL BASIC PRICIPLES OF PHYSICS AND THERMODYNAMICS – Don’t get sucked into the BS that those two companies are selling.
Also the pricing of those systems – Honestly if you’ve ever seen a DD or Dynapak, you would be wondering where that $100,000+ price tag for an AWD unit and $50,000+ for a 2WD unit comes from. I can sell you an MD-100 with a bigger Eddy Current, knurled rollers and no flywheel inertia and sell it for less than $35,000 and call it the direct competitor to a Dyno Dynamics. Because that’s what you are getting. They sell a product that doesn’t have the ability to do everything ours does for double the price…anyone else see a problem with this?
SevenFour – we use an Eddy Current for loading capabilities.
On that topic, Mustang was the PIONEER and ORGINATOR of Eddy Current Dynamometers….no one else. We’ve been doing EC dynos for over 15 years. We must be doing something right because look at the companies that followed us….
Dynojet – was inertia only dynos, now running EC’s on their 224x
SuperFlow – was water brake only dynos, now running EC’s
Land & Sea – was water brake only dynos, now running EC’s
Dyno Dynamics – exact copy of the old Mustang emission dynos we’ve been producing for 15 years
Dynapak – still using the old concept of using fluid pressure to control load (same as a water brake)
I’m sure I’ve pissed a few people off – Flame suit on
Tim
Sales Engineer
Mustang Dynamometer
Code:
  Engine RPM	 Total Power	 Engine Torque
         RPM	         HP	     Ft-Lbs
2501	67	139
2516	68	139
2531	68	140
2545	68	140
2559	69	140
2573	69	141
2586	70	141
2601	70	142
2615	71	143
2629	72	143
2645	73	144
2660	73	145
2675	74	145
2689	75	146
2704	75	146
2719	76	147
2734	77	147
2749	78	148
2764	78	149
2779	79	149
2794	80	150
2809	80	150
2824	81	151
2839	82	151
2854	83	152
2869	83	152
2885	84	153
2900	85	154
2915	86	154
2931	86	155
2946	87	155
2962	88	156
2977	89	157
2993	90	157
3008	90	158
3024	91	159
3040	92	159
3056	93	160
3071	94	161
3087	95	162
3103	96	163
3119	97	164
3137	98	165
3154	100	166
3170	101	167
3187	102	168
3204	103	169
3221	105	170
3238	106	172
3255	107	173
3273	109	175
3291	110	176
3309	112	178
3327	114	179
3345	116	181
3363	118	184
3382	120	186
3401	122	188
3420	124	190
3440	126	192
3460	128	195
3480	131	197
3501	133	200
3522	136	202
3543	138	205
3564	141	207
3586	143	209
3607	145	212
3629	148	214
3651	151	217
3672	154	220
3694	157	223
3717	161	227
3742	165	231
3767	169	236
3793	174	240
3819	178	245
3847	183	250
3874	188	255
3902	194	261
3929	200	267
3958	205	272
3987	211	277
4017	216	281
4049	221	286
4080	225	290
4111	230	294
4143	235	297
4176	239	300
4207	242	302
4239	245	304
4271	248	305
4303	249	304
4334	251	304
4365	251	302
4396	251	301
4426	252	299
4454	251	297
4482	252	295
4510	252	294
4534	252	292
4561	252	290
4588	253	289
4620	254	288
4648	255	288
4676	257	288
4705	259	289
4733	261	289
4760	263	290
4788	264	289
4817	265	289
4845	267	289
4873	268	289
4900	270	289
4927	271	289
4955	273	289
4982	274	289
5010	274	288
5037	275	287
5065	276	287
5092	278	286
5117	278	286
5143	279	285
5168	280	285
5195	281	284
5221	280	282
5247	280	280
5273	280	279
5298	279	277
5324	279	276
5346	279	275
5369	279	273
5390	279	272
5412	279	271
5436	279	269
5463	279	268
5486	280	268
5509	281	268
5533	282	268
5556	283	267
5579	283	267
5602	283	266
5625	284	265
5648	285	265
5670	285	264
5691	285	263
5713	285	262
5736	285	261
5758	285	260
5779	285	259
5800	285	258
5821	285	257
5842	285	256
5862	284	254
5883	282	252
5903	281	250
5922	279	247
5942	277	245
5960	276	243
5977	274	241
5994	273	239
6010	272	237
6028	270	236
6044	269	234
6061	269	233
6077	268	232
6095	269	231
6113	269	231
6131	269	231
6148	269	230
6164	270	230
6181	270	229
6198	269	228
6214	269	227
6231	269	227
6247	269	226
6262	268	225
6278	268	225
6293	268	224
6309	268	223
6324	268	222
6340	267	221
6355	267	221
6370	266	220
6384	265	218
6399	263	216
6414	261	214
6428	259	212
6441	257	210
6452	256	209
6463	255	208
6475	254	206
6486	252	205
6500	250	203
Old Aug 4, 2005 | 11:38 AM
  #35
SevenFour's Avatar
My 2c
I live within 20 miles of 3 dyno jets (1 AWD) and a Dyno Dynamics, I've seen them in action many times. I've seen the correction factors entered into the DD dyno, I've seen the numbers change. I've seen the setup of a DynoJet prior to doing runs, I've seen what's entered and what can be minipulated.
How can you possibly say that the DynoDynamics Power Graphs and scaling are good? They look like ***. The owner of the DD dyno near me can't get the graph to display peak TQ & HP #s at the same time (could be him, or it might not be possible). Like I said, it's a good tuning dyno, with really crappy software. The logging is great but the interface blows man, and the "Print out" program is a joke; it's like MSPaint but with less options. Perhaps my neg. views on the DD software is due to the operator of the local dyno, if it is I'd love for you to show me how capable it is.
You can't tell me that every DD dyno will read within 2% of eachother because every owner can input a different correction factor. I've gone from DynoJet to DynoJet and seen them read LESS than 2% of eachother.
I've been on/worked with DynoJets, Clayton & DynoDynamic dynos. And out of all of them the DynoJets have given the clearest curves & the best experience.
Sorry, I've never used a Mustang and couldn't remember if it was EC or WB. Like I said, I like the mustangs read-outs it and from what I've seen screen caps of and talking to people who use them the GUI is fairly intuitive.. Looks like a very good dyno.
Old Aug 4, 2005 | 12:12 PM
  #36
strikethree's Avatar
Originally Posted by plokivos
yeh, i do wish someone would do a sae corrected mustang dyno on different model evo and figure this out.
dynograph and 1/4 mile time will be great with it.
but then again, really, you could have the fastest evo and driver could produce some horrible results.
I also noticed that this forum is completely going toward drag racing.
With doing auto-x, i wouldn't want my evo to spool up at 6000rpm, no matter how much power i have.
With the low peak whp and tq, i would still be happy if my spool is fast, engine responsive is quick, consistant and balanced with least possible amount of lag.
hear hear! there is no way an evo will ever be a fully respectable drag racing vehicle. what a waste. the car is not about straight lines. yes, power is important, but it is not the main focus of the vehicle. will 1,000 HP and a slow spool help you get a better lap time at laguna seca compared to 500HP and a quick spool with a driver training course?
strike
Old Aug 4, 2005 | 12:42 PM
  #37
Dyno4mance's Avatar
I’m sure I’ve a few people off – Flame suit on
Tim
Sales Engineer
Mustang Dynamometer
Code:
         RPM	         HP	     Ft-Lbs
2501	67	139
2516	68	139
2531	68	140
2545	68	140
2559	69	140
2573	69	141
2586	70	141
2601	70	142
2615	71	143
2629	72	143
2645	73	144
2660	73	145
2675	74	145
2689	75	146
2704	75	146
2719	76	147
2734	77	147
2749	78	148
2764	78	149
2779	79	149
2794	80	150
2809	80	150
2824	81	151
2839	82	151
2854	83	152
2869	83	152
2885	84	153
2900	85	154
2915	86	154
2931	86	155
2946	87	155
2962	88	156
2977	89	157
2993	90	157
3008	90	158
3024	91	159
3040	92	159
3056	93	160
3071	94	161
3087	95	162
3103	96	163
3119	97	164
3137	98	165
3154	100	166
3170	101	167
3187	102	168
3204	103	169
3221	105	170
3238	106	172
3255	107	173
3273	109	175
3291	110	176
3309	112	178
3327	114	179
3345	116	181
3363	118	184
3382	120	186
3401	122	188
3420	124	190
3440	126	192
3460	128	195
3480	131	197
3501	133	200
3522	136	202
3543	138	205
3564	141	207
3586	143	209
3607	145	212
3629	148	214
3651	151	217
3672	154	220
3694	157	223
3717	161	227
3742	165	231
3767	169	236
3793	174	240
3819	178	245
3847	183	250
3874	188	255
3902	194	261
3929	200	267
3958	205	272
3987	211	277
4017	216	281
4049	221	286
4080	225	290
4111	230	294
4143	235	297
4176	239	300
4207	242	302
4239	245	304
4271	248	305
4303	249	304
4334	251	304
4365	251	302
4396	251	301
4426	252	299
4454	251	297
4482	252	295
4510	252	294
4534	252	292
4561	252	290
4588	253	289
4620	254	288
4648	255	288
4676	257	288
4705	259	289
4733	261	289
4760	263	290
4788	264	289
4817	265	289
4845	267	289
4873	268	289
4900	270	289
4927	271	289
4955	273	289
4982	274	289
5010	274	288
5037	275	287
5065	276	287
5092	278	286
5117	278	286
5143	279	285
5168	280	285
5195	281	284
5221	280	282
5247	280	280
5273	280	279
5298	279	277
5324	279	276
5346	279	275
5369	279	273
5390	279	272
5412	279	271
5436	279	269
5463	279	268
5486	280	268
5509	281	268
5533	282	268
5556	283	267
5579	283	267
5602	283	266
5625	284	265
5648	285	265
5670	285	264
5691	285	263
5713	285	262
5736	285	261
5758	285	260
5779	285	259
5800	285	258
5821	285	257
5842	285	256
5862	284	254
5883	282	252
5903	281	250
5922	279	247
5942	277	245
5960	276	243
5977	274	241
5994	273	239
6010	272	237
6028	270	236
6044	269	234
6061	269	233
6077	268	232
6095	269	231
6113	269	231
6131	269	231
6148	269	230
6164	270	230
6181	270	229
6198	269	228
6214	269	227
6231	269	227
6247	269	226
6262	268	225
6278	268	225
6293	268	224
6309	268	223
6324	268	222
6340	267	221
6355	267	221
6370	266	220
6384	265	218
6399	263	216
6414	261	214
6428	259	212
6441	257	210
6452	256	209
6463	255	208
6475	254	206
6486	252	205
6500	250	203
Spoken like a true sales manager touting thier product.....
Old Aug 4, 2005 | 01:01 PM
  #38
Precision Dyno's Avatar
Originally Posted by Event-Horizon
DynoDynamics is THE best. Like the saying goes, you get what you pay for. So, who cares what the price of the dyno is if the tuner wants to provide the best.
I do think that a mustang dyno and a DD dyno are similar in many respects. I just like output provided by the DD, and the many different sources it can log. I think in this game consistency is key.
Let me try to clarify what I meant. I seem to be having a hard time getting thru....
After 1 year of research My list of prospective dynos to purchase went to three.
1. Dyno Dynamics
2. Mustang
3. Dyna Pack
Dyna Pack was appealing for many reasons. FOR ME it was the portability and accuracy of the measuring equipment.
Unfortunately, After seeing some in action and the time it would take me to set up vehicles in a volume shop, I decided it wasn't going to work for me. FOR ME. Not to say for others it can't work well.
Second the price was a concern. Over $100k for the AWD model with the right attachments and such.
(these will be brief and lamen explanations)
So it was foward from there.
Dyno Dynamics was and still is my FIRST CHOICE for the best overall Dyno money can buy. I won't get into too many technicalities, but it really is what they say it is.
MY ONLY ISSUE is the fact that my Budget couldn't afford the 120k+ for the AWD model. Let me repeat that I said it was only a budget related issue. I One day would love to own one.
Then we went to Mustang with a proposal. They came up with a Package for us that we couldn't put down. For the work I do here and in the future it was perfect for me and MY Budget. At $80K I got every option I wanted including the Motorcycle package I wanted for my clientel. It is a true load bearing dyno with very easily navigated software. It DOES THE JOB BETTER than 99% of the dynos on the market for MUCH less.
Note a Dynojet NEVER even came up on the list. As a tuning facility you can not say that you have a dyno that can tune a street driven vehicle with one of those units. Without steady state tuning it is Impossible to dial in Optimal ignition and Fuel for a given cycle. WOT runs do not tune the low throttle section with optimal torque value.
That is a fact. You can guess and interpolate load cells with the help of a knock sensor, but it will not be optimal.
Just like people say a dyno is a tool, so are sensors like EGT's, Knock sensor and O2 to name a few.
Your best tool in your box will then be your Brain. With the right VE calculations and the proper load bearing device, a stand alone EMS can be tuned flawlessly for drivability.
End of my rant
Old Aug 4, 2005 | 01:12 PM
  #39
SloRice's Avatar
Except I tout FACTS, not internet BS...
Old Aug 4, 2005 | 01:18 PM
  #40
Dyno4mance's Avatar
1. Dyno Dynamics
2. Mustang
3. Dyna Pack
Second the price was a concern. Over $100k for the AWD with the right attachments and such.
MY ONLY ISSUE is the fact that my Budget couldn't afford the 120k+ for the AWD . Let me repeat that I said it was only a budget related issue. I One day would love to own one.
End of my rant
At last someone that is talking sense...
Old Aug 4, 2005 | 01:24 PM
  #41
Dyno4mance's Avatar
My source of information is not gleaned from the internet as most do..... but I draw from experience gained during many late nights spent tuning all sorts of vehicles and engine management systems....
Old Aug 4, 2005 | 01:29 PM
  #42
Event-Horizon's Avatar
Hey Tim, who cares about a dyno that cant even do partial throttle load. Can your dyno allow someone to see changes made at partial throttle at a particular cell....
What I ment to say was, can you see the output at the tire change in real time as timing is introduced during partial throttle? I have seen with my own eyes a DynoDynamics be able to easily do this.
From what I have seen in the past, the graphs that a mustang produces look like something a kid with a crayon and a ruler has drawn. How can you possibly see changes that are made in a single cell on a graph or do you have another screen like the DD which enables you to see these small changes in real-time?
Old Aug 4, 2005 | 01:44 PM
  #43
SloRice's Avatar
OK, since you edited your statement, so will I.
You obviously didn't comprehend what I said about how based on the laws of an internal combustion engine it isn't possible to maintain the exact same amount of horsepower for the duration of a steady state test. It just doesn't happen. Therefore, how can a dyno say that it does??
Yes you can see changes with our system when timing is adjusted. But if you want such a finite resolution of 1-2HP by adjusting timing, then you are tuning that motor so close to the edge of destruction and I would never let you touch my car.
Old Aug 4, 2005 | 01:55 PM
  #44
gsujeff55's Avatar
Originally Posted by DynoFlash
Mustang is the best for tuning
Dyno jet is the best for comparing dyno to dyno power
ever even tuned on a Dyno Dynamics?
Old Aug 4, 2005 | 03:28 PM
  #45
Yes I can see real time increases and decreases in the software while in steady state.
I use this everyday to tune fuel and timing curves.
But mostly for fuel. The timing values are increased or decreased in 3-6 degree increments while specifying a constant speed or load. It works very well.
But I don't hold the vehicle there for a specific amount of time. Depending on the EMS software you can go thru the load cells in a timely fashion. It gives plenty of resolution to optimally tune timing values.
If you have good knowledge about the specific application, you should be close to the timing values needed based on the VE table that has been created on the basic fuel map. By datalogging the stock ECU at various load sites and drive cycles prior to tuning it will allow you to see the basic formation quickly. Using that information your ignition tuning time speeds up without having to spend too much time in a specific load cell. Some nice increases in power can be seen when you are at partial throttle all the way up the range.
Partial , low, mid or WOT, it doesn't matter. The Mustang Dyno still allows you to be under a programmed load at all times. Its nice have the rollers control the car instead of the other way around.
