Just dynoed my car tonight
Old Aug 1, 2005 | 05:47 PM
SR20DE-T's Avatar
I dynoed my car tonight on a DYNOJET at my friends shop. My car is a 2005 EVO MR w/2100mi on it with just a HKS TI catback running 93 Octane and 4th gear runs
1st run my car made 225.74 hp and 250.90 lbs of torque 94.19 degrees F 41% humidty SAE Corrected 1.01
2nd run made 227.90 hp and and 251.20 lbs of torque 94.64 degress F 41% humidity SAE Corrected 1.01
Outside Temperature was 82 degrees and 65 % humidity
I dont have the AF ratio numbers did not put it on. Just a fun run to test out his new DYNOJET. I was the first AWD to test out his dyno. How are the numbers for the conditions and a cat back?
Old Aug 1, 2005 | 05:53 PM
Evo442's Avatar
Most places do 3rd gear runs on the dyno, dont they?
Old Aug 1, 2005 | 05:58 PM
RazorLab's Avatar
Not on a 6speed MR
Old Aug 1, 2005 | 06:41 PM
Rastmp's Avatar
I got 277WHP on my stock 2005 RS ....I posted the dynosheet some months ago..
Acording to the guys at Proven, it is the most HP they have seen on a stock EVO...
225 seems low..I would check for a boost leak..
Old Aug 1, 2005 | 06:45 PM
Nesiop's Avatar
225 is low for an MR on a dynojet should be about 235-240
Old Aug 1, 2005 | 07:29 PM
saywhen's Avatar
I don't know what my car did stock but with tbe, 10.5, cams, cam gears, xede on 91 I did 318hp and 325tq on a dynojet temp outside was around 100. I am not sure how that helps anything. I just wanted to type something I guess.
Old Aug 1, 2005 | 07:30 PM
DynoFlash's Avatar
I would like to offer you a complimentary Dyno Flash to test and report back with your results
Old Aug 1, 2005 | 07:34 PM
MitsuJDM's Avatar
3rd gear you'd probably make 400ish :P
Always use the gear cloest to 1:1 ratio
I've heard of 240ish WHP stock. :-/ Could be the dyno too.
Old Aug 1, 2005 | 07:37 PM
Silk's Avatar
^ OOooo i would take that if i was you
Old Aug 1, 2005 | 07:41 PM
SiCKlEyWiKeD's Avatar
does seem kinda low
Old Aug 1, 2005 | 07:51 PM
lookEVO's Avatar
ill take a complimentary flash...........PLEASE.
Old Aug 1, 2005 | 08:35 PM
PeteyTurbo's Avatar
Where did you get your car dyno'd at??Just curious because we both live in the same city..Mabye I'll see what mine makes..
Old Aug 1, 2005 | 08:38 PM
SR20DE-T's Avatar
Petey you know one my friends he has a white STI, you meet him I think from ETown. I live in China Town. My friends dyno just a few blocks away on 13th and Hamilton near Spring Garden.
Old Aug 1, 2005 | 08:39 PM
jshin80's Avatar
isn't the 5th gear ratio is 1:1 on 6 speed???
usually 5th gear is ~1:1 on 6speed tranny.
where 4th gear is ~1:1 on 5speed tranny.
i don't know much about MR cause i don't have one...
Old Aug 1, 2005 | 08:40 PM
SR20DE-T's Avatar
How can you tell if your car has a boost leak, or the cheapy plastic recirc valve is leaking?
