boost on stock evo 8?
Damn, people, what's up with all the guesses and misinformation? A quick search gleans all of this info. 5.slow got it right for 05s. They spike at just over 20psi in stock form, but then taper down to near 17 by redline. 03/04s are lower with 19.5psi spike or so tapering down to 16.
Asking what boost the stock motor can take is not a complete question. Many factors play into this, and you have to give more details in to what is being truly asked before an answer can be given.
yes you can get a flash, walbro fuel pump, and head studs which will allow you to run more boost than stock with a manual or electronic boost controller..then you can totally build the pistons rods etc. to hold much more boost while running either race fuel, alcohol injection etc..like the above post its very dependent on what you're talking about and what your goals are
