Exhaust Flage Rubbing On Drive Shaft!!!
Old Aug 2, 2005 | 06:18 PM
Jeff_Jeske's Avatar
Exhaust Flange Rubbing On Drive Shaft!!!
http://www.jeffjeske.com/rubbing.jpg
Anyone else notice the rear flange on their exhaust rubbing on the driveshaft?
It appears that the stock hangers allow for enough play that the flange bumps the drive shaft every now and then.
Anyone have a fix for this?
Old Aug 2, 2005 | 06:22 PM
keviin's Avatar
damn it now i have to go check my car and get all dirty... but in your pic i don't see any sign of it bumping... i don't see any scrape marks... btw.. what exhaust do you have?
Old Aug 2, 2005 | 06:24 PM
Thegame's Avatar
I'm gonna have to check mine too
Old Aug 2, 2005 | 06:47 PM
keviin's Avatar
no rubbing here.. i have buschur 3"tbe.
Old Aug 2, 2005 | 06:57 PM
sleet's Avatar
^ I have that same exhaust and mine was touching the driveshaft, my problem was that my mid-pipe wasn't pushed onto the downpipe all the way and my mid-pipe came off the DP on an angle and was directed at the driveshaft, simple fix.
Old Aug 2, 2005 | 09:18 PM
Jeff_Jeske's Avatar
Um...there are scrape marks.....
For me its the rear hangers allow too much movement. Everything else is nice and tight. Keep in mind I noticed this while installing SMART. I never heard it hit or anything so I imagine it was during very aggressive driving.
Old Aug 2, 2005 | 09:20 PM
SlowCar's Avatar
go to a muffler shop and have them fix/shorten the hangers
Old Aug 2, 2005 | 09:21 PM
xLaNcErEvOx's Avatar
i had that problem because i installed my test pipe backwards... so try installing it the other way around...
Old Aug 2, 2005 | 09:27 PM
Erik@MIL.SPEC's Avatar
Or try the Kartboy stiffer bushings.
Old Aug 2, 2005 | 09:28 PM
Jeff_Jeske's Avatar
The testpipe is reversable with no change to the direction of the flange. There is only one way for the mid pipe to go or the rear O2 wont fit. I may just add some tension with wire but I wanted to see what others have done. I'm sure I am not the only one....others may not even know its happening.
Old Aug 2, 2005 | 09:32 PM
SlowCar's Avatar
dont do a ghetto fix, fix it right once and for all
Old Aug 2, 2005 | 09:33 PM
Jeff_Jeske's Avatar
You are soo very right.....(its the DSM blood in me) Do you have a link to those hangers?
Old Aug 2, 2005 | 09:43 PM
hkfeet's Avatar
http://www.kartboy.com/
Old Aug 3, 2005 | 07:05 AM
sleet's Avatar
^ That is what I was going to recommend.
Old Aug 3, 2005 | 07:29 AM
EVIL_EV0's Avatar
The new hangers will fix the problem!
