Samco Radiator Hoses Question
When replacing the radiator hoses with the samco ones would i need to do this in any special way? Or can i just simply take the stock ones off, drain a little of the coolant, then put the samco ones on?
Im just wondering if i will have air bubbles in my lines that will cause problems later on.
youll wanna burp it
put it all together
add water/coolant till it seems no more can go. start the car. let it run. when it gets to temp the tstat opens. and you will need to add more. repeat until no more water can go in and cap it.
put it all together
