Replace Front PADS only, what do yo guys think?
I just saying it doesn't make sense... No need to become a smart as$ about it.
Originally Posted by BADEVO
You can take Newtons law and divide it by E=MC squared and get the square root of whatever you want. I am telling you the rear pads on many EVO's wear faster then the fronts. Slice it dice it smother it cover it do what ya like, facts are it happens and it has happend to more then 1 or 2 people. Matter of fact my service tech told me most EVO's he see's are like this. Ask Newton to go figure it out and get back with us when he does please.
Originally Posted by 03EvolutionVIII
I just saying it doesn't make sense... No need to become a smart as$ about it.Not being a smart ***, I was jokin. Hence the
smiley at the end. Sense of humor... I think Lancershop has em ..... (lets try this again)
The rear pads wore faster on my evo aswell. but when i changed the brake pads for the second time the rear pads had plently more left then the front. the second time i was using a diferent pad in the rear then in the front...
Originally Posted by KZEVO
the rears will wear faster if you use the hand brake when the car is parked. I will highly recommend the Ferodo DS2500. Make sure you put the stock brembo pad shim on the aftermarket pad to prevent squeeling. I've done that and the Ferodo's hardly ever squeel.
Originally Posted by SlowCar
The parking brakes does not use the pads. There is a second set of "drum brakes" in the rear rotors.
My rear brake pads also wore out first. Specifically the inside pad. While the front may take most of the braking forces, the rear pads are much smaller and may be made of a different compound. It isn’t straight Newton with these things it has more to do with the engineering decisions that went into the car. I’ve got 48000 miles on my car and the fronts still have a good deal of life left in them. I changed the rears to DS2500s at about 28000 miles. When I took my fronts out to look at them a few months ago I did see the tops and bottoms of the pads appeared to have a 45 degree shear plane broken off about 0.5” from each end. I thought that was a bit odd.
Best wishes,
F86sabre
Best wishes,
F86sabre
Best wishes,
F86sabre
Best wishes,
F86sabre
my rear went out too first. a lot quicker then the front ones. I think it's my braking style.
but i guess if you could find a deal for both front and rear pad, it might be cheaper for you that way.
otherwise, hawk pads are relatively cheap.
were those the factory brakes that was missing the shims and broke off?
that's not good...
that's not good...
hmmmmm. So many opions......It was looking like the fronts only at first, but the further I read it seems that the rears may need it......I guess I will have to check which ones need it first....I know one of them needs it because my brake light is comming one, and every day it stays on a little bit longer than the day before....
Has anyone else heard of these pads......this seems way cheaper than any other price I have seen for PADS on this car.....and where did you get this pads from?
thansk guys this is really helping...
Originally Posted by JuniorRSX!
You could try bendix pads... i paid 27.97 for the fronts(D1001) and 22.96 for the rear(MKD961). and they perform the same as stock.
I had aboiut 10K and I had done the fronts twice and the rear once. 2 to 1 is pretty saf. Just double check the rears. Sneak a peak and you will be able to tell if you need to replace them or not.
that's not good...
I have no idea why the shims would be missing...in theory, it's locked in there, I obviously could only just use half of each shim as the other half were originally glued onto the OE Brembo pads...I didn't bother to chip and glue that other half on the new pads...is this what people are talking about?
Advanced Auto. Don't laugh... the pads work as good as the oem ones. but they need about a week till they grab the same, don't know why? I've had them on my car for almost three months now and not one single squeal, unlike the stock pads. they also come with a quality shim that has a sticky backing so it stays on the pad and doesn't vibrate. you should also use a high temp copper anti-seize compound. there's a section that explaines this in the how to's.
It's not an advanced auto pad, it's by Bendix, advanced auto is just one of the places that sells them.
Last edited by JuniorRSX!; Aug 9, 2005 at 03:37 PM. Reason: i put autozone by mistake....
This is crazy, why would no one have brought up the cheaper version of pads.......(I do believe you BTW), but if they work just as good. I mean thats why I was going to go with the Hawks, because I thought they were as good as the Stockers, but if Autozone has a set for 20 somthing.......dam that just sounds to good to let go, expecially since I am in a money situation.........hmmmmmmmmmmmmm
Autozone. Don't laugh... the pads work as good as the oem ones. but they need about a week till they grab the same, don't know why? I've had them on my car for almost three months now and not one single squeal, unlike the stock pads. they also come with a quality shim that has a sticky backing so it stays on the pad and doesn't vibrate. you should also use a high temp copper anti-seize compound. there's a section that explaines this in the how to's.
