Trackday Rotors: Stock or Slotted?
I need to replace my stock EVO rotors soon. They have survived over 20 track days with racing pads grabbing them all day. The car has 22,000 miles, of which at least 4,000 are track miles. The stock rotors held up well.
Should I replace them with another stock set, or get aftermarket rotors (slotted? drilled?), and if so, what brand?
Thanks.
Thanks.
i would stick with stock.
i tried the R1 concepts rotors and they cracked after 6 track days or so . . . and didn't perform noticably better or worse than stock.
the 2-piece floating performance friction rotors crack a bit too after track use (someone on socalevo.net did a write up and report, i think his name was earlyapex)
wt??? weren't you the one talkin' all that **** to david on socal? why are you even asking this question? and why would you wanna get stock rotors again?
nils has a pretty sick car. are you running pfs?
heh i always see richevos car at rre... like every time i go. how's that radiator workin' out? cuz justin told me that he was puttin' in the pwr biggie rad in your car.
But our stock rotors have a few strikes against them. They're heavy and the design of the internal vanes makes for poor cooling efficiency (in fact, stock rotors don't even have real vanes...just a bunch of posts). In my view, the ideal rotor would be a 2-piece, plain, directional vane design.
Originally Posted by nils
yup... the PF's work great for me...
Emre
I was going to go with Brembro slotted rotors, all the way round, and frodeo pads. I wanted to get brembo rotors to go with the calipers (i believe are stock rotors are made my mitsu).I dont really like drilled rotors but really like slotted. I have had slotted rotors on a couple of my cars and I felt a great inprovement. Also most race cars and such use slotted rotors and i never seen race cars with drilled rotors.
Originally Posted by trinydex
you never glazed pads? cuz that's what the scraping is for...
For the record, slotting (a.k.a., "gas slotting") was NOT conceived to prevent pad glazing. In fact, pad glazing isn't even an issue in high-performance driving...it's only an issue with sunday drivers on the street. Like cross-drilling, gas slotting was originally designed to prevent "green fade" when the resins holding organic pads compounds together would vaporize from the pressure. That's why it's called gas slotting: the slots allow the gas between the rotor and pad surfaces to escape. Modern ceramic, metalic, and other high-carbon brake pads simply do not outgas to any noticable degree. Cross-drilling and slotting is largely an anachronism these days.
Emre
There's no way you can "feel" an improvement in braking comparing brand-new stock rotors to brand-new slotted rotors. Slots do not increase brake torque in any way...and that's what you feel.
Emre
Originally Posted by EvOJoHnY0312
hawk has two diff. kinds of pads one for street use and the other for track use only
Emre
