Flash Results Of 2005 Evo With Meth, 280's On 28 Psi...
i went to turbotrix today and had them flash my car again. I was very happy with the results. I was stuck their all day due to some technical dificulties that turbotrix worked out with me in the best possible manner. After the meth not spraying, boost not going over 21 psi, then boost not staying under 30 psi, missing software, etc... and 20 pulls I left with 379.4 whp and 372 wtq. Temperature in the dyno room was 95 degrees. my AFR was between 11.2-11.4. timing was barely touched. The car feels like an animal now. Boost is around 28-29 psi failling off to 26-27 psi. basic mod list below:
Hks 280/280
3" TBE
Buschur delux fmic
Injen intake/upper pipe
Hks Dli2 Twin power
Walbro pump
Boost controller
SMC trunk mount meth injection kit
If i can scan the sheet i'll post it up. I'll be at E-town this weekend running my car, looking for 11.9 or better!!!
Hks 280/280
3" TBE
Buschur delux fmic
Hks Dli2 Twin power
Walbro pump
Boost controller
idk man, if your going to be at E-town this weekend you can come see for yourself. the car holds 26 psi pretty well to redline. there is no modifications done to the turbo
No i'm not worried about longevity, this turbo will be off the car in less then 10k
i'm using a jdm mr bov which flutters in 5th so i might get a greddy type rs
I'll be there also going for 11.9 but with a guesstimated 340whp, but who knows. I don't think I'll get a chance to see you hold 26psi to 7800 rpm, or whatever your rev limit is, though. I won't even be hitting 26psi PEAK, but no one else has ever held boost that high for more than a brief moment or two. Maybe your boost gauge is off?
