gauge install -- question
Old Aug 25, 2005 | 04:28 PM
webguy330i's Avatar
How many of you who installed a gauge or set of gauges went through the factory firewall grommet? I'm entertaining the idea of doing the evomoto 2nd firewall hole mod... comments? Is it necessary?
I'll be running 3 gauge wires through there to my control link...
Old Aug 25, 2005 | 05:16 PM
justchil's Avatar
There is a decent hole on the passenger side.. you could make it bigger but it might be a PITA to get a drill in there. I just like the fact that is away from everything. I have a pic if you're not sure what I'm talking about.
It should be more than enough room depending on how many/thick the wires are.
Old Aug 25, 2005 | 05:21 PM
kmcconn9's Avatar
hmm, I dont know what hole you are refering to without seeing it...but I went thru the grommet on the FAR right side of the passenger firewall. The one that is practically impossible to get to from either side...I have a pic you you want.
Old Aug 25, 2005 | 08:21 PM
Jakeg97's Avatar
https://www.evolutionm.net/forums/sh...+gauge+install
Old Aug 25, 2005 | 10:14 PM
webguy330i's Avatar
Originally Posted by burningmoney97
Good find, I couldn't find it myself -- I may be dumb today
Thanks for the info guys, I decided not to run the wiring today but I did get my CH panel + gauges in the car and the radio relocated.
I will likely follow the evomoto write-up on creating your own firewall hole since I need to run 4awg through there next week for the amp install.
