Defi gauge help!!
Old Aug 26, 2005 | 05:35 PM
turtlelancer's Avatar
Defi gauge help!!
I installed a defi d boost gauge it was working fine.. but today i turned on my car and the needle sits at zero.... it normally sits at 18-20 vac. I checked the lines and nothing is loose, i think the gauge fried ... This was installed no more than 2weeks ago... this sucks. I wonder if the heat has anythign to do with it.. i touched teh gauge and it was really hot cause it was sitting in direct sunlight. i dunt kno damn
Old Aug 26, 2005 | 05:41 PM
ddubb's Avatar
this might be stupid, but did you already check the electrical line and ground wire to be sure they are tight too. just a thought
Old Aug 26, 2005 | 06:08 PM
ok umm i went for a drive... the vac kicks in after i drive for a bit but at idle it reads 0!!! someone chime in!!
Old Aug 26, 2005 | 10:46 PM
ashumo's Avatar
i would pull your vacuum line and and make sure there are no kink, bends, or leaks in it. then reconnect it.
i had the d gauge, never had any problems. hope you figure it out.
Old Aug 26, 2005 | 10:48 PM
timzcat's Avatar
Okay, I know the answer but I am not telling you because it's been covered a million times.
Old Aug 26, 2005 | 10:55 PM
DA-Evo's Avatar
come on help the guy out
Old Aug 26, 2005 | 10:57 PM
bigjhoney's Avatar
Here i helped... click this link
https://www.evolutionm.net/forums/search.php
