mileage for tranny fluid changes
Old Aug 30, 2005 | 05:22 AM
jonathanVIII's Avatar
hi, ive searched the forum and i was unable to find info on when to perform the first and subsequent tranny fluid changes. please post what mileages and also what fluids you suggest for a car that will be in cold weather. i'd rather run the same fluid in all the components to make things easier. thanks
Old Aug 30, 2005 | 05:25 AM
also, if i run the front end up on ramps then jack the rear with a hydraulic jack (to get car level), is that enough support or do i need jackstands in back
Old Aug 30, 2005 | 05:39 AM
Robert_K's Avatar
1: use Jack stands!!! You don't want the lift to fail or roll out.
2: every 5000miles. Here you go: http://www.lancershop.com/customer/p...&cat=15&page=1
DIY: http://www.evomoto.com/tech_info.php?tPath=2&tech_id=26
Old Aug 30, 2005 | 05:42 AM
mump's Avatar
service book says 15k for severe and 30k for normal use. I suggust do the 1st one ALOT early than that though. also OEM for the diffs.
Old Aug 30, 2005 | 05:52 AM
Robert_K's Avatar
I bought mine at 13k miles and never change it and now I'm replacing my front diff. When Mitsu opened the TC they said there wasn't any oil in it. So unless you want to drop $1500 on the part for a 1/2 hr job and couple bucks, I would change it every 5k miles. I will from now on.
Old Aug 30, 2005 | 07:47 AM
thanks guys, i can use the Mitsubishi GL5 LSD Gear Oil for the manual transaxle, transfer case, and rear differential?
Old Aug 30, 2005 | 07:52 AM
Jeff_Jeske's Avatar
Hopefully this was under warranty.
I put penzoil sychromesh in my tranny. I change that every three oil changes. Its cheap.
I use OEM oil in the transfer and rear diff. I changed them at 15k and it still looked like new .... and I beat the living snot out of this car.
Old Aug 30, 2005 | 07:58 AM
Robert_K's Avatar
Nope it wasn't under warranty. Why I'm buying the Quaife LSD diff now. I now will be useing the OEM LSD oil and the Penzoil Sychromesh as well.
Old Aug 30, 2005 | 08:21 AM
koo i guess ill use that combo too. i plan on changing them at 8000mi when i do my second oil change. 15k tranny changes sounds ok to me, most of my everyday driving (to/from work) is a steady 45 mph
Old Aug 30, 2005 | 08:31 AM
gsujeff55's Avatar
i don't think you are supposed to use GL5 in the tranny. I would use a full 90w in the t-case such as royal purple max gear...or the diaqueen stuff. I think mitsu is calling for the dealers to put the same thing in the tranny and t-case right now....and thats ****. Caused my t-case to take a dump about 1k miles after they filled it.
