o2 Mechanical fix help
Old Sep 5, 2005 | 08:45 PM
Jarrett H's Avatar
I need pictures of the mechanical o2 mod fix because the thread in the "how to" has broken images. Anyone have pictures saved or possibly a link?
Old Sep 5, 2005 | 09:23 PM
PunoEvo1337's Avatar
here is a pic of the Helix one from gruppe-s, I dont have a pic of it on the car
Old Sep 5, 2005 | 10:12 PM
bigjhoney's Avatar
Its pretty straight forward, you dont really need pictures. Get the 2 antifoulers, drill a 1/2" holde right through the middle of 1. Screw the one you drilled into the undrilled one. Go to the car and unscrew your o2 sensor, screw the antifoulers in its place, then screw the o2 sensor into the antifoulers. By doing this is, less exhaust enters through the path of the antifoulers causing your check engine light to stay off. If you still need pics let me know cause i have them saved.
Old Sep 5, 2005 | 10:29 PM
SlowCar's Avatar
yep, go to autozone or checkers.....a pair of 18mm anti-foul plug should cost you <$6
Old Sep 5, 2005 | 10:37 PM
Jakeg97's Avatar
looks ok to me
https://www.evolutionm.net/forums/sh...d.php?t=114931
