help with 10.5 install
Old Sep 8, 2005 | 08:55 AM
GOKOU's Avatar
Originally Posted by deadbeatrec
very very cool, thanks for all the replys. i mostlikly will do the install with a mechanic that i work with. well he used to be a mechanic now he is an engeineer. but he said he will help me for like 30 an hour. so i will let everyone know how the install goes.
$30 an hour and you're doing the work??? Follow the instruction and find a friend to help you and save the money .
Old Sep 8, 2005 | 08:59 AM
deadbeatrec's Avatar
he is helping me if not doing it all . i thought that was a good deal seeing how i will pay double where he used to work.
Old Sep 8, 2005 | 06:43 PM
Deepseadiver's Avatar
Drain the raidator coolent into some jugs then you can re-use it. I think it was less than 2 gallons.
Old Sep 8, 2005 | 07:02 PM
smack_evo's Avatar
i would say remove the radiator since it's so quick and easy, but if you're dead set on
leaving it in then you can slid a piece of cardboard on the face of the radiator to protect
the fins.
Old Sep 9, 2005 | 12:19 PM
erioshi's Avatar
If you don't remove the radiator, at least put something over the fins. I generally put a piece of doubled up cardboard in front of the radiator when I remove my turbo - just a little extra protection. Removing radiator is actually pretty easy, too.
Old Sep 9, 2005 | 01:56 PM
rlazer5000's Avatar
^^ that's a damned good tip!
Old Sep 9, 2005 | 02:41 PM
webguy330i's Avatar
Don't forget a can of PB Blaster
Old Sep 9, 2005 | 03:29 PM
damianhindley's Avatar
30 bucks amn hour is not bad. gotta look at it his way. its like your paying for training. I am a mehanic also for usaf and i charge 25 an hour on the outside and 30 if someone is help. most of the time its harder with all the questions and stuff. But for this job just read up and tackle it your self, not a hard job at all
