knock level reading zero??
Old Sep 9, 2005 | 04:57 PM
dave9172's Avatar
for some reason lately, i noticed my knock reading on my safc2 does not change from zero, no matter how much i step on the gas. any advice. i had an alarm installed recently that couldnt have anything to do w/ it could it? any advice?
Old Sep 9, 2005 | 05:07 PM
8urv8's Avatar
thought I saw somewhere that the s-afc2 doesn't give an accurate reading anyway. I don't use mine.
Old Sep 9, 2005 | 05:09 PM
li1p1aya's Avatar
+1
Old Sep 9, 2005 | 05:10 PM
BoostWhore's Avatar
An alarm shouldnt have anything to do with that.
Old Sep 9, 2005 | 05:14 PM
dave9172's Avatar
im just wondering why it was working fine before and now it does nothing at all. those idiots that installed my alarm aready screwed my gauge lights up
Old Sep 9, 2005 | 05:16 PM
Thegame's Avatar
they probably did something to it during the alarm install... luckily my alarm went well so far.
Old Sep 9, 2005 | 05:18 PM
4TUN8's Avatar
Blah
dave9172's Avatar
it sucks when ever my headlights are off my lights for my gauges are on, and when my headlights are on at night my gauges are off and i cant see anything, it sucks. i have an appointment sunday to get it straighten out.
Old Sep 9, 2005 | 05:22 PM
dave9172's Avatar
also after the alarm install, i started having idling problems w/ my car, my cel came on(code was related to maf sensor) and whenever i stepped on it the car had no power. it turns out someone put all my safc2 settings out of wack. i know those guys who installed my alarm had something to do w/ it, but there is no way to prove. it was all fine before the alarm install though.
Old Sep 9, 2005 | 06:42 PM
GOKOU's Avatar
I'm seeing the same thing with my safc II in regards to knock. If I go to the setting then it changes but under monitor it read 0, nada.
Old Sep 9, 2005 | 07:25 PM
honda-guy's Avatar
try recalibrating the knock sensor on the safc, and make sure you do it in your driveway after the engine warms up.
Old Sep 9, 2005 | 07:33 PM
GOKOU's Avatar
Is there a procedure on how to do this??
TY
Old Sep 9, 2005 | 08:17 PM
SicLanEvo's Avatar
So the EVO does read count knock on the SAFC2? The 2g eclipse could not read knock on the SAFC2 for some reason.
Old Sep 9, 2005 | 08:27 PM
honda-guy's Avatar
TY
yes, it's in the user manual. i think most people who thinks the safc doesn't read knock right on the evo is because they didn't calibrate it right. you need to calibrated it for two specific rpm range so that it doesn't pick up engine noise as knock. and you should recalibrate it after you add each engine mods that will effect how the engine will run and sound.
Old Sep 9, 2005 | 10:23 PM
GOKOU's Avatar
Forgot where I put my manual but I tried doing that one time and it didn't work. Appreciated if anyone would list the directions here.
Thanks.
