getting sick of bad idle....
Originally Posted by dave9172
im changing my bov to jdm mr dv, hoping this will correct the issue some if not all. anyone else have the same problem?
We need to know more prior to helping you.
What mods do you have? when did it start happening? how long has it been going on? etc.
lately it seems to be getting worse. whenever i come to a stop, whether it be in nuetral or gear, it goes down 500-600rpm then after a few secs back to around 1000. if the ac or heat is on its even worse. i recently had an alarm installed, somehow my safc2 settings were changed, when i got the car back it ran like complete crap. ive had my settings put back in. the car overall runs back the way it used to, but the idle is still crap.
stop venting to the atmosphere.. youre screwing up the maf readings and eventully will damage the motor... dont believe me, find timzcat, he did a write up on this prob.. im tired of repeating myself..
i ordered my jdm mr dv from gruppe-s a month ago. still havent got it. it was on backorder. i called up yesterday about it. they said the order expired out of there computer system, cause it had been in there too long?? so i re-ordered it again yesterday. cant wait to get it. hope ir makes a difference w/ the idle!
Go back to the stock intake (put a K&N dry drop-in filter in it) and get a recirc BOV (Greddy Type-S, JDM MR, etc.). That should take care of your idle problems.
l8r)
l8r)
Forge RS Valve
I have the Forge RS valve in Rec and it works better than anything i have ever used on any of my car's before if your going to spend Money might as well get something that you can use with any setup you may have down the road. and has a life time warranty, try that with many of the other valve and they will most likely tell you to buy a new one.
