Turbo question to new owners...
Old Mar 8, 2003 | 04:07 PM
hornet's Avatar
Question Turbo question to new owners...
I haven't seen anybody ask this yet but.....do you have to wait a few seconds to let the turbo cool previous to turning the Evo off like the WRX?
Old Mar 8, 2003 | 04:17 PM
evo_dan's Avatar
Re: Turbo question to new owners...
This is the rule of thumb with any turbo after hard use. It's not really for the sake of the turbo so much as it is for the sake of the oil in the turbo and what happens to the oil while the engine isn't running. The turbo itself can withstand extreme heat.
Old Mar 8, 2003 | 04:20 PM
Evilution's Avatar
On every turbo car you should let the car idle for about 1 minute or so before shutting down. I mentioned it in another post but depending on how hard you drive it will determine how long you should let it sit. After being stopped at a light or slow driving I would let it sit say 30-45 seconds before shutting down. It already had some idle time and didn't get abused much. Driving a couple of WOT runs but calm for a few minutes before parking give it a minute. Hard driving on a track or mtn run let it sit for at least 2 minutes. These are safe numbers to go by. I highly recommend a turbo timer as this can get annoying depending on how much of a rush you're in.
Old Mar 8, 2003 | 04:43 PM
gjhsu's Avatar
It really isn't necessary on the WRX either because it uses a line that continues to cool the turbo even after the car is shut off. I don't know the technicalities behind it, but that's what it's supposed to do. To be on the safe side, though, I usually let the car sit for half a minute or so before shutting it off.
Old Mar 8, 2003 | 06:25 PM
leonard_shelby's Avatar
No **** ...? A post oiler ? I've never heard of such a thing.
Old Mar 8, 2003 | 08:37 PM
MalibuJack's Avatar
The oil tends to burn off or evaporate with the heat, leaving behind ash or additives, I think I mentioned this before, its called coking. an Engine pre-oiler, or post-oiler (pressurized container that feeds oil into the engine after it shuts down) helps.. But if you run 100% synthetic oil, it doesnt 'coke' on the bearings and therefore is less harmfull to the turbo and bearings. I think that is why Mitsubishi requires it. Though its never good to run a car hard when its cold, and just shut down a turbo car without letting it cool down, mitsubishi and most manufacturers understand that its a fact of life in the US market that cars are neglected and they need to do all they can to reduce warranty claims.
Old Mar 9, 2003 | 03:39 PM
hornet's Avatar
Thanks, I was just wondering cause when my friend got his WRX the dealer actually told him to let it cool. Although I've driven a lot of different cars with different configurations non of them were turbo so I learned something new...
Old Mar 9, 2003 | 04:49 PM
tryandcatchme's Avatar
After a hard run, just drive the car under 3,000RPM like one mile before you hit your driveway. Thats all you need, dost waste $200 on a TT.
Old Mar 9, 2003 | 06:01 PM
Evilution's Avatar
Regardless of hard driving or not the turbo still needs to drain out the residual oil and thus have a cool down period. While yes you can save $$$ by sitting in your car and waiting I personally don't always have the time nor patience. I certainly wouldn't recommend anyone to follow the above advice. If you plan to keep the car awhile play it safe and be kind to your car. If you're the type to swap parts every 6 weeks and do constant maintenance then maybe you don't worry about it. Never in all my years has anyone suggested the above quote. Just something to think about.
Old Mar 9, 2003 | 06:29 PM
Trbo Dad's Avatar
Are we gonna be able to put a TT on with the way the car locks/unlocks the doors on it's own?
Old Mar 9, 2003 | 08:59 PM
evo_dan's Avatar
I also second this. Driving under 3000 rpm is not enough, but can help shorten the time you need to wait before shutting down the engine.
Secret Chimp's Avatar
The Evo owners video (the video the dealership makes you watch before giving you your keys) mentions that you should let the Evo cool down for a minute or two before shutting off.
SC
Old Mar 9, 2003 | 09:52 PM
Evilution's Avatar
According to one of our early owners the auto lock/unlock feature can be disabled. So I assume we can definitely install a TT.
Old Mar 9, 2003 | 10:10 PM
SilverEvoVIII's Avatar
anyone got an idea on either A) how hard it is to install a turbo timer. and B) case i dont wanna mess it up, how much they cost to get put in. and C) do you know anyone who does it in teh souther eastern Mass area???
Old Mar 9, 2003 | 11:49 PM
Evilution's Avatar
You should be able to buy one and have it installed for anywhere between $150-225. Depends on what brand you go with and who installs it. If you're lucky I'm sure you can find a used one or really good price and have the whole thing done under $150. They aren't that hard to install but depends on the car and the tech. HKS has one for $95 plus $15 for a harness. Don't know if they make a harness for the Evo yet. With that you should be able to plug it in with no hassles. Install time should be less than an hour for a shop.
