Gauge pod and Gauge combo
Old Oct 3, 2005 | 12:45 AM
  #31
Jakeg97's Avatar
Originally Posted by Talon
Why the hell would someone want to get a gauge put somewhere that blocks the speedometer?! I can't understand this reasoning.
cause it has a smooth finish
looks oem
Here's what mine looks like... easy to read and out of the way of everything else:
yes its out of the way, but it looks tacky and cheap to me
like something you could buy at walmart
Old Oct 25, 2005 | 01:53 PM
  #32
steevo's Avatar
[QUOTE=burningmoney97]cause it has a smooth finish
looks oem
Thats exactly why i ordered it. Should be getting in the two parts tomorrow! Cant wait (1st mod). I was concerned too about seeing the speedo, b/c i am short. But with the autometer pod, the boost gauge will be so close to the tach....i like that. The clean look though is awesome. I see Bucher is selling a similar pod for $50 bucks...wonder if its autometer?? I dont want to drill holes in the stock steering column , so i will be using tape only.
Old Oct 25, 2005 | 02:03 PM
  #33
Jakeg97's Avatar
[QUOTE=steevo]
looks oem
i get people asking if the gauge is oem cause of the clean look
btw - the supplied tape in the kit didnt work for me , so i used a thin piece of velcro
Old Oct 26, 2005 | 09:40 AM
  #34
steevo's Avatar
tape didnt work?? that sucks. I guess i'll be playing around with mounting the pod when i get it in today....hurry UPS! I guess i'll try velcro if needed...as long as i dont drill the steering column b/c i will probably upgrade pod/gauges in the future.
Old Oct 26, 2005 | 10:32 AM
  #35
AWDTurbo4's Avatar
very nice, what do you all think of this?
Old Oct 26, 2005 | 11:40 AM
  #36
fast lane's Avatar
Originally Posted by Aux.
"depreciating Investment"
Isn't this an oxymoron?
Old Oct 26, 2005 | 12:09 PM
  #37
staatz's Avatar
Yes..but a good way to describe
Old Oct 26, 2005 | 12:18 PM
  #38
sirloin1219's Avatar
looks oem
acutally it looks really good where it is. that's the same gauge and the same place i put it. i mean i dont really need to stare at the gas gauge much you know? also, it's not held in place by a piece of tape but by screws. looks good.
Old Oct 26, 2005 | 12:24 PM
  #39
SterlingEvo's Avatar
I have the autometer dual gauge steering column pod. I don't have it taped down or anything, it just sits there perfectly... I wanted to be able to take it off without leaving holes or sticky residue. This view isn't "normal", I ususally drive with the steering wheel all the way down and the SAFC hidden. The gauges block the bottom of the MPHs and the GAS level, that's it.
Old Oct 26, 2005 | 12:25 PM
  #40
sweet_bucket22's Avatar
carbontrix.com
They have nice gauge mounts. All CF. That is what I run. I think they have 3 different gauge setups for the EVO/Lancer.
Old Oct 26, 2005 | 12:37 PM
  #41
HksSSq's Avatar
the combo works good. but definately need to use better double sided tape / velcro / glue
OK, i take it that on that gauge the Triangle marker is the amount you boost you running .. do you have to set that marker manually. or does it set automatically
Old Oct 26, 2005 | 12:38 PM
  #42
Probably manual, like a diving watch bezel...
Old Oct 26, 2005 | 12:54 PM
  #43
Jakeg97's Avatar
manually
Old Oct 26, 2005 | 12:59 PM
  #44
Jakeg97's Avatar
Originally Posted by sweet_bucket22
carbontrix.com
i only see the 8 pillar mounts for the evo http://www.carbontrix.com/
but rmr makes a nice carbon fiber steering wheel mount http://www.rodmillenstore.com/produc...ategory=access
Old Oct 26, 2005 | 01:13 PM
  #45
Mr. Slappy's Avatar
I couldn't live with the speedo blocked out. I like to see past 120 mph personally.
