Need Help Fast
Old Sep 17, 2005 | 11:41 PM
Evo VIII's Avatar
Need Help Fast
Ok, right now I am stuck at my friends house and when I put my key into the ignition, the key is stuck in the lock position and won't turn. This happened to my other key and I thought it was a dud but it happened again with this key. I am pretty it is the immobilizer has this ever happened to anyone and if so does anyone know what to do?
Old Sep 17, 2005 | 11:43 PM
spm1024's Avatar
is your steering wheel locked?? take the pressure off the wheel and it should turn
Frozenrock's Avatar
i know this may sound stupid but did you try and turn the steering wheel when you turned the key ???
eling99's Avatar
im not 2 sure this will help but..try moving the steering wheel while turning the key!
Old Sep 17, 2005 | 11:46 PM
AWDrift07's Avatar
+1 for the steering wheel lock
Old Sep 17, 2005 | 11:47 PM
djskyy's Avatar
werd....
Old Sep 17, 2005 | 11:49 PM
Evo VIII's Avatar
I tried turning the wheel and it did not work, thanks for the help but im stuck at my friends house and i need to get home. Any other ideas??
Old Sep 17, 2005 | 11:53 PM
AWDrift07's Avatar
its not the immobilizer because you would still be able to turn the key. The immobilizer runs off the ECU. The car would start for a second and then shut off. Try turning the wheel back and forth while turning the key.
Old Sep 17, 2005 | 11:54 PM
keviin's Avatar
is your friend a girl? lol
Old Sep 17, 2005 | 11:59 PM
gabesir's Avatar
yeah is your friend a girl?
and have you try turning the steering wheel?
Old Sep 18, 2005 | 12:01 AM
Evo VIII's Avatar
Last time this happened i got a spare key and it worked without me turning the wheel. I never turn the wheel when turning the car on. Even now when i turn the wheel back and forth and turn on the key at the same time, it still isnt working. For some reason i thought it was the key cuz of what happened. Thanks for the quick posts. I will call AAA or something tomorrow. Any more ideas will help, no matter what time.
ThEyElLoWoNe's Avatar
all i can think of is the same thing that everyone else is sayin!! the steering wheel is locked!!
Old Sep 18, 2005 | 12:04 AM
Evo VIII's Avatar
No shes not a girl, why do you think im trying to leave....this would be a Blessing from God if it was a girl..I'll be a awake a little while longer then im going to bed....not with him!!! Haha
Old Sep 18, 2005 | 12:05 AM
AWDrift07's Avatar
sounds like your key wasn't cut properly. use the spare as your primary. get new keys. get your car flat bedded, it will be covered under your mitsubishi warranty assuming yours isnt voided.
Old Sep 18, 2005 | 12:06 AM
Frozenrock's Avatar
is the car in gear ??
