Race gas on stock evo?
Old Sep 20, 2005 | 04:44 PM
MitsuEvoIIX's Avatar
is this safe to do at the track on a stock evo? maybe 50/50 ration or something?
Old Sep 20, 2005 | 04:50 PM
nutrulz's Avatar
works fine, leaded gas may eventually kill O2 sensors.
Old Sep 20, 2005 | 04:59 PM
04EVO's Avatar
I run 5gal. of 100 octane unleaded and fill the rest with that 91 octane crap. It runs a lot smoother.
Old Sep 20, 2005 | 05:07 PM
4TUN8's Avatar
Do not use leaded gas in a car that has catylitic converters, it will ruin them with the quickness.
Old Sep 20, 2005 | 05:10 PM
MM Racing's Avatar
Unless you plan on uping the boost somehow then race gas is useless. Sire your car loose all chance of knocking but it shouldn't anyhow with how rich the factory made it then with the race gas you are just compounding the issue. I bet you run slower with race gas if you are trully stock with no boost control.
Old Sep 20, 2005 | 05:20 PM
Curt@MrLed's Avatar
Former Vendor
stock, its a waste of money.. unless your running in 150 degree heat or 10,000 feet above sea level..
Old Sep 20, 2005 | 05:42 PM
AWD_SR71's Avatar
Basically there's no reason to run higher octane fuel unless you're experiencing engine knock - if you cranked up the boost or advanced the ignition timing to the point of inducing knock then you can run up to 109 octane unleaded without hurting the Cat. Though you'll probably only need half 91 and half 100-109.
Old Sep 20, 2005 | 08:28 PM
roys44's Avatar
Evo's are made to run on 93 octane. So if you are stuck with 91, like California owners, your car will run better if you boost the octane.
Old Sep 20, 2005 | 08:32 PM
Fa$[- a$ $hi[-'s Avatar
you can run race gas at the track, no problem. just don't do it very often. i run it and have yet had a problem. even if it does screw up the cat in the long run, i'm just going to get a high flow cat in it's place. no big deal.
Old Sep 20, 2005 | 09:02 PM
jmartinez1170's Avatar
u better use a wideband and a afc to run this safely in your car and yes dont use leaded gas 100 oct should be fine.
Old Sep 21, 2005 | 12:17 AM
Jakeg97's Avatar
go for it
Old Sep 21, 2005 | 05:38 AM
evodave's Avatar
From: driving the 10 second beast in ohio or running lightmods.net
race gas will richen up the mixture a lot on your car...be sure you have a point in doing that such as abilities to moniter and modify your a/f ratios and such.
Dave
Old Sep 21, 2005 | 06:38 AM
theblue's Avatar
pointless and will make the car slower. (richer = slower) and evo's already come very rich.
