dyno question
Old Sep 20, 2005 | 09:18 PM
teddy's Avatar
dyno question
just want to know on difference dyno is the result (whp)we be a lot of difference or almost same ,and long time ago i remember one magazine show all the difference dyno test result ,if some people has it can u post it on .
thanks a lot
Old Sep 21, 2005 | 05:41 AM
GTVEVO's Avatar
There are alot of varibles to each and every dyno. Dyno Jets usually are known to read the highest. Dyno Dynamics are usually known to read the lowest. This being in a regular uncorrected enviroment. All the others fall inbetween but you can't really put all of them together into one catagory. The best advice I can give you is pick one dyno and only use that one only. Testing your gains and tuning for gains is what the dyno is used for. A high HP number is just there for bragging writes.
For example I know cars that dyno 250-300hp that run in the 11sec range at the strip.
