intake pipe w/o tune
Old Sep 21, 2005 | 02:30 PM
Creamo3's Avatar
Originally Posted by Thegame
I have to agree with Warrtalon on this one. My MR DV never flutters... Well maybe a tiny little bit at partial throttle, but no more than the stocker.
Exactly, you are not supposed to be fluttering at all.
Old Sep 21, 2005 | 02:33 PM
dsm95hybrid's Avatar
Originally Posted by Creamo3
If you actually search the JDM BOV you will see that this is not an isolated instance as it has caused idle problems when people come to a stop ( idle dips) and flutters under boost. Maybe at your level of mods you aren't maxing out the valve, but there are better valves out there.
Speaking of... 2005+ model year will not have this problem as they basically have an HKS EIDS equivelent built into the ECU circuitry.
Old Sep 21, 2005 | 02:35 PM
If it is not fluttering, then it likely leaks at idle. If you VTA then you will notice your valve will be opening, which disrupts a/f at idle.
Old Sep 21, 2005 | 03:44 PM
ZK's Avatar
ZK
Do we? Anyone can confirm this? So the 05s can vent the BOV to atmosphere and not have to worry about idling?
Old Sep 21, 2005 | 03:46 PM
Try it, but not with the stock plastic one. One that holds closed at idle.
It has been confirmed on multiple 2005's down here.
Old Sep 21, 2005 | 03:47 PM
eling99's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=143847
i ran the ssqv vta..the sound was cool and all...but not worth the performance lost....i changed it to mr dv!!!
edit: no idle problems!!!
Old Sep 21, 2005 | 04:32 PM
avaien's Avatar
Will I see a performance decrease with the intake pipe? I know about the maf problems but I thought that was due to after market cone filters and such.
Old Sep 21, 2005 | 04:36 PM
avaien's Avatar
Also what boost would be safe to run with my mods w/ aftermarket bov?
Old Sep 21, 2005 | 04:37 PM
Soon2BEVO's Avatar
I thought the open air filter that aftermarket intakes have is what caused the MAF readings to go haywire thus creating a lean situation in case of the EVO. Is it the intake pipe and not the filter or both? For instance, if I kept my Helix Intake pipe but put back on my stock cold air intake would it function OK?
On another note, my JDM MR BOV does not flutter. Only at very very low RPMs in 5th gear and such but this started when I installed my cams I believe. Either way, it doesnt buck the car at all and it holds the boost I ask it to. $100! cant beat it!
Old Sep 21, 2005 | 04:39 PM
Turbolover's Avatar
i have a HKS inlet pipe and a drop-in HKS filter. i have NO problems w/the set-up!!! i am NOT tuned either. i was running an open-ended filter and had all kinds of problems(boost spikes, too rich,and fuel cut-off!) i highly RECOMMEND the HKS inlet pipe w/ur stock box and a drop-in filter!!!
Old Sep 21, 2005 | 04:57 PM
Warrtalon's Avatar
Do you have 1/4-mile times or dyno numbers to support this claim? MalibuJack disagrees with your recommendation.
Originally Posted by MalibuJack
(Specifically referring to the BR Cone filter only) I did not have any issues with stalling at all until I installed a MAF pipe, the filter alone really doesn't do any harm, well, it causes the car to run marginally leaner, which is worth a few horsepower, but it never appeared to make my car dangerously lean.
There's a few good explanations of why the MAF pipe causes stalling, but essentially when the pipe had bends that made the inlet and outlet parallel, the airflow from the recirculation valve, or any small amount of surge, would directly disrupt the MAF readings and could cause stalling. As David said, by using only one angle, the airflow would have to go around a turn to disrupt airflow which meant it was no longer at just the right angle to confuse the sensor. HKS addresses this by tapering the size of the pipe up from the turbo to the Maf, which in theory should slightly decelerate the airflow. But Dave's solution seems to work best in most cases.
I wanted to also add that many other intake "Kits" do replace the intake and MAF pipe, in those cases you will need a retune since they alter the MAF readings in different ways. Overall they lower the MAF reading which can cause the car to run marginally, to severely lean, thats why its very important to get the car tuned when you make modifications.
THere are some filters that will alone alter the MAF readings, ARC is a good example, there are others that I can't think of offhand, but it has alot to do with how the airflow is directed INTO the MAF at that point. Most cone-only filters won't really give you too much grief.
Old Sep 21, 2005 | 05:03 PM
It will make it run rich, not lean. So SAFE, but not optimal for performance.
Old Sep 22, 2005 | 03:57 PM
TURBODAWG's Avatar
Just FYI, the
JDM MR Bov starts to crack open and leak at ~21 psi.
Stock BOV starts to crack open and leak at ~19 psi.
I tested this on an aparatus I made at home.
Any time you leak pressurized air, you are heating up the air MORE THAN what is needed to make that boost pressure without the leak. So a leak is a BAD thing, no matter how much/ or how little.
Brian
Old Sep 22, 2005 | 04:30 PM
Soon2BEVO's Avatar
Originally Posted by TURBODAWG
Just FYI, the
Brian
I tested my JDM MR BOV and it started to leak at 24psi. It held closed compeltely at 23psi. I run 22.5
Old Sep 22, 2005 | 05:03 PM
Warrtalon's Avatar
Same here, and the stocker opened at 13psi, not anywhere close to 19.
