Over Filling Engine Oil Question
Old Sep 22, 2005 | 12:36 PM
MetalGear214's Avatar
I did my oil change and I put the whole 5 quart bottle, the dipstick is over the highest line. I drove the car normally for about 1 week then and it was all fine, then last nite I open it up. My check engine light came on! so knowing I over fill the car I drain some oil out then drove around and the light came off. my question is
Did I hurt the engine in anyway?
What should I check for to see if anything is wrong with the car?
please I need your advice, thank you in Advance
Old Sep 22, 2005 | 12:46 PM
bump for help!
Old Sep 22, 2005 | 12:50 PM
Tsurara's Avatar
You'll be fine. You only overfilled it by .2 or .3 Qts or so, you'll burn that off in a month. If you underfilled it you might have to worry.
Old Sep 22, 2005 | 12:51 PM
But the check engine light came on, I want to know the reason for that. I am one of those guys that worry to damn much besides its a 30K car
Old Sep 22, 2005 | 12:58 PM
BUMP this again sorry!
Old Sep 22, 2005 | 01:04 PM
juyanith's Avatar
Er, I'm confused. You're worried about the light, but you weren't worried about driving it for a week after you knew it was overfilled? In any event I doubt you did any real damage, but if you're really concerned about the CEL get the code pulled. Even if you did hurt something it's too late to do anything about it other than fix whatever breaks. Without knowing what the CEL was for, there's really no way to know if it is related -- it may have nothing to do with the oil level.
Old Sep 22, 2005 | 01:12 PM
The light came off after taking some oil out and driving it for like 10 mins. So i am pretty sure that the CEL was for the oil being over filled, I drove It like that cause i think it going to be fine, Its no like I put 1 quart extra.
Old Sep 22, 2005 | 01:25 PM
Ev0ikon's Avatar
code reader is your friend.
Old Sep 22, 2005 | 01:57 PM
fsugatorbait's Avatar
If your as worried as you say you are go get the code pulled.
Old Sep 22, 2005 | 02:05 PM
can I just go to autozone and get that pulled?
Old Sep 22, 2005 | 02:07 PM
4TUN8's Avatar
yes
Old Sep 22, 2005 | 02:56 PM
EvOJoHnY0312's Avatar
i have a question i blew the motor at 35,000k well it was a knocking noise but they gave me a beand new bottom end and i broke it in like they told me and them put a boost controller on after like 4,000k on the motor and now recently its been making that noise again what to do need help please please is it under warranty
Old Sep 22, 2005 | 05:38 PM
Jakeg97's Avatar
why did you drive your car knowing the oil was over the highest line?
Old Sep 22, 2005 | 09:32 PM
Reducer's Avatar
I too put 5 quarts in, and it was over the line. I haven't gotten a CEL from it though. I was a little shocked when I checked it, and it was over, as the manual states that the filter and pan capacity should equal more than 5 quarts. Next time I will put a little less in.
Old Sep 22, 2005 | 09:34 PM
Soon2BEVO's Avatar
Overfilling is very bad for the engine. However, .2-.5qts over isnt THAT bad... a whole quart is bad!!!
