best shift knob for MR
Old Oct 6, 2005 | 07:44 PM
EX-STI GUY's Avatar
The best shift knob for the MR is the OEM Mitsubishi shift knob which is blue and silver. Matches the blue recaro seats. This is an OEM option in Japan and it is better constructed than the USDM version. Look at the website of Japan Parts where I ordered mine. Love my shift knob. Exactly the same as the stock one but the two pieces are actually bolted together rather than glued together like the stock one. If you look closely at your silver MR shift knob you will notice that there are just indentations on the top of the knob. The JDM version actually has hex bolts in each hole holding the 2 pieces together. Fits perfectly since it is an OEM item and has the same 6 speed design found on the stock MR shift knob. Feels all together different in your hand than the USDM shift knob. Only downside is it is a bit pricey.
Ex-STI Guy
Old Oct 6, 2005 | 07:54 PM
KTT's Avatar
KTT
my avitar gets excited about the razo counterweight
Old Oct 6, 2005 | 10:47 PM
Ivan MR's Avatar
Originally Posted by MR 8U
Stock MR shift knob rocks.
Yea unless it has been sitting in direct sunlight Hot!!
Old Oct 7, 2005 | 12:04 AM
GarageRM's Avatar
Originally Posted by 7for8
greddy cw?
that might not work with a 6mt cause of the position of the Reverse gear in 6mt.
you have to use a spacer for it.. to rise the shift knop up a bit..so you can use Reverse with no problem.
Emit_1
Nov 8, 2016 10:56 AM
pizdets
Sep 8, 2016 12:45 PM
LI_NY8
Sep 5, 2015 05:50 PM
Dolfandrus
Dec 18, 2010 08:10 PM
dpl2
Nov 17, 2008 01:16 PM
