Will this mod void our so called "warranty"?
Old Oct 3, 2005 | 10:27 PM
05evoGSR's Avatar
I plan on installing a braided SS clutch line, B&M adjustable short throw shifter w/poly-urathane bushings. While im in the process of doing that i was going to remove the restrictor in the slave cylinder for better clutch engagment. I know the clutch mod is not visible nor detectable unless its looked for but not sure if Mitsu will void anything for a clutch line. If it comes down to it i could always put the stock shifter back on if needed. Let me know.....
Old Oct 3, 2005 | 11:54 PM
BuLocal's Avatar
Its my understanding that it will, even though your setup is probably better for the trans than the stock setup.
Old Oct 4, 2005 | 06:41 AM
sirloin1219's Avatar
i assume it will as well
Old Oct 4, 2005 | 06:43 AM
TxEvo8's Avatar
Mitsu will consider almost anything to void the warranty.
Old Oct 4, 2005 | 06:44 AM
GOKOU's Avatar
Sorry but once you drive the car off the lot ---------------> No warranty
Old Oct 4, 2005 | 06:45 AM
hotrod2448's Avatar
It will if it is found. It is not however better for the driveline. The restrictor is there to help prevent shocking the driveline with a launch. Taking it out will increase your chances of breaking things.
Old Oct 4, 2005 | 06:54 AM
dan628's Avatar
It should only void the warranty on the part you replaced....
Old Oct 4, 2005 | 06:56 AM
GOKOU's Avatar
Yeah it should but don't work like that in the real world
Old Oct 4, 2005 | 07:14 AM
Kordwood's Avatar
Or anything related to or dependent on that part. In this case, the entire transmission.
Old Oct 4, 2005 | 07:18 AM
sleet's Avatar
Mitsu are queers, it all depends on the dealership.
Old Oct 4, 2005 | 07:24 AM
CnGEvO8's Avatar
Hopefully you have a good dealership. Mine wouldn't even replace something that came defective from the factory so any mods are out of the question!
Old Oct 4, 2005 | 07:27 AM
bdking57's Avatar
unfortunately since people continue to do 6500 rpm launches and or cant drive stick properly none of us can get decent warranty coverage.. probably a good reason why the X will be a paddle shifter car.
Old Oct 4, 2005 | 07:31 AM
walkedu's Avatar
It all depends on the place you take it to. I live in a small town that NEEDS business and will do warranty work no matter what you've done to it.
Old Oct 4, 2005 | 07:41 AM
GOKOU's Avatar
warranty work needs to be approve by but a good dealer should fight for you. sucks! dealership sucks even more!
Old Oct 4, 2005 | 07:47 AM
chrisw's Avatar
general rule of thumb, "if you think it will void your warrentee, it probably will"
