questions..
Old Oct 5, 2005 | 10:19 PM
Itchy's Avatar
questions..
i know im most likely going to get flammed on this and everyone is gunna tell me to search but i tried to no avail.. anyways got a mech. defi d boost gauge off someone i know and it didnt come with the vaccum line. so i wanted to know how long i should get to route it to the steering column. also i went to autozone and they said that they do all the cutting and everything and wasnt sure how thick the line is. also what other parts do i need to pick up to install this because im sure that it onl came with the gauge+wires, so i think i need a "T"fitting? err
think theres a write up on installing the boost controller also so probily going to try to do it in one sitting..
so just wanted to know what tools and things i need to go out to buy b4 i get started on this project thanks and if flamming.. be easy on me
(p.s. grammer isnt perfect so dont kill me on that)
Old Oct 6, 2005 | 12:53 AM
BuLocal's Avatar
The tubing that comes with the guage is 10'-5". How long it will need to be will depend on where you want to mount it and how you route it through the firewall. I went through the rubber gromet tucked behind the passanger side shock tower and installed the guage in an A-pillar pod. I think this is the longest way to do it and I used every damn inch. You could probably knock off a foot or two if you are mounting to the steering colum or taking a shorter route through the firewall. What you will need: 1)guage , 2)vacum tubing , 3)T-fitting , 4)a couple of real small zip ties , 5)wire cutters & what ever else to ground one wire and tap the other into green & white striped wire in your dimmer switch assembly (wire cutters, solder, shrink tubing, electical tape, razor blade, more zip ties, etc. , 6)guage pod or mounting bracket. Here are the how to's:
https://www.evolutionm.net/forums/sh...ad.php?t=98114
http://www.evomoto.com/tech_info.php...3_9&tech_id=14
I'm not sure what size the tubing is, the Defi maual doesnt say, just bring the guage with you to the auto parts store. I just did this a couple of days ago, good luck.
