how much does your evo weigh?
Old Oct 11, 2005 | 02:59 PM
acidandroid's Avatar
sh*t!!!!!!
r u serious our sunroof weighs 40lbs!!!!
that's a lota weight on the roof
u make me regret that i got this option now
i thought it's like 10lbs (the motor)
Old Oct 11, 2005 | 03:01 PM
Remember that the slickevo guy has a sunroof (40lbs) and all of his seats, not that the rear seat weighs anything.
he's got cf trunk, and no wing
i got stock trunk and stock wing plus rear diffuser
his rear end must weigh a lot less than mine i would imagine
Old Oct 11, 2005 | 03:02 PM
EVOIIIM3's Avatar
Gas is around 7lbs a gallon.....
You know gross weight is not the only number, where the weight is can be even more important!
Old Oct 11, 2005 | 03:04 PM
thanks for the weigh of gas
i was curious about that
and yeah, i think my rear end is light enough, that's why i'm afraid to save more weigh with CF trunk at the rear end
but its' nearly impossible to save more weight at the front
and if the sunroof really weighs 40lbs, that sucks
i bet that hurt the performance a lot by making the center of gravity so high up
Old Oct 11, 2005 | 03:06 PM
bigjhoney's Avatar
I personally dont think carbon fiber hood/trunk save much, their both aluminum and weigh nothing really as it is.
Old Oct 11, 2005 | 03:07 PM
Warrtalon's Avatar
Yeah, that's why the MR and RS both have aluminum roofs, which are not only much lighter than the sunroof'd GSRs, but also lighter than the GSRs with the normal steel roof. This lowers the center of gravity like you said...
Old Oct 11, 2005 | 03:08 PM
johny719's Avatar
i think the scale he used was wayy off then, i know some of them can be inaccurate.
Old Oct 11, 2005 | 03:14 PM
EVOIIIM3's Avatar
front, remove entire AC system, move the battery to the trunk, find some CF or glass front panels.
It's really hard to believe that the EVO is a 3400lbs car! It's tiny, and doesn't have any real electronic gadgets in it.
Old Oct 11, 2005 | 03:15 PM
my varis cabon hood weighs 6.2kg = 13.7lb
stock hood weighs 9.7kg = 21.4lb??
i got this from varis website
Old Oct 11, 2005 | 04:44 PM
unowned's Avatar
If this were true the Enzo would be made of Aluminum instead of Carbon Fiber... Carbon fiber without fiberglass is very light compared to aluminum
Old Oct 11, 2005 | 04:51 PM
ray3328's Avatar
Now I'm not saying that your car doesn't weigh 2951 lbs. But if it does you should post what you took out and what you replaced. That's alot of weight you had to take off while keeping a full stock interior and you have a sun roof.
Old Oct 11, 2005 | 04:58 PM
Oppie20's Avatar
Since the paper factory is PAYING for raw material by the pound I would bet that scale would be light.
Try it at a weigh station or something calibarted byt the state.
Old Oct 11, 2005 | 05:04 PM
Alias's Avatar
I thought I saw a post recently saying someone weighted the stock hood and it was like only 16lbs.
Old Oct 11, 2005 | 05:06 PM
ok, i 16lbs sounds right
i took that # off varis website, it's wrong then
Old Oct 11, 2005 | 05:26 PM
joeymia's Avatar
The stock hood is real light. Also the reason a CF trunk weighs less than stock is because they usally are not braced for a wing.
