how much does your evo weigh?
Old Jan 4, 2006 | 07:30 AM
  #46
powersmx5's Avatar
My friends 03 evo with sunroof but no Jack or spare weighed 3200 pounds on the button on the scales at the last Solo II tour event the car was AS prepared with a few gallons of gas. I think the scale was reading a little high they said my SM2 miata weighed 2430 pounds I went to a local race shop with calibrated scales to get it corner weighted and the reading was 2325 thats with roll bar, hitch, big *** supercharger. I dont see anyone taking off 450 pounds unless you started drilling holes in panels and cut the trunk off. For a car thats already pretty spartan its hard to get that much weight. You could always cut or grind down the extra threads on the bolts on the suspension and engine compartment might be worth a few pounds.
Old Jan 4, 2006 | 07:34 AM
  #47
mike1023's Avatar
humm lol nothing left in my car. no carpet. no door panels. only one seat. it is posable to take that much plus more out. of car. im not even done with every thing out. this weekend maybe i can get the rs belt with no ac te 1505 belt size and then can take out ac thats a good what 30lb plus sunroof will be another 30-40. there is another 60lb to take off. so im sure i can do it.
Old Jan 4, 2006 | 07:38 AM
  #48
Silencer's Avatar
I'll back slickevo18. Mine is at 2985 in SCCA STU trim w/ sunroof (03'). Here is the initial weights from Mitsu. This is probably dry weight so add an additional 50-75 lbs for fluids.
WEIGHTS
GVWR (lbs/kg) 4222 / 1915
Curb Weight (lbs/kg) [w/ sunroof] 3263 / 1480 [3298 / 1496]
Weight Distribution (% f/r) 60 / 40
FWIW, I have no cf hood or trunk.
Dave
Old Jan 4, 2006 | 07:53 AM
  #49
djtmotorsports's Avatar
I weighed my car when it was new on my race car scales
3301lbs with a full tank of gas, sunroof, full interior and big wing
Darin
Old Jan 4, 2006 | 07:57 AM
  #50
Silencer's Avatar
Darin
Looks like I guessed wrong, 3298 w/sunroof is Mitsu's wet weight.
Thanks for the info!
Dave
Old Jan 4, 2006 | 08:10 AM
  #51
GPTourer's Avatar
Originally Posted by bigjhoney
I personally dont think carbon fiber hood/trunk save much, their both aluminum and weigh nothing really as it is.
Evo trunks are steel. RS is thinner steel for '05+.
Old Jan 4, 2006 | 08:28 AM
  #52
alloyic_rs's Avatar
steel or aluminum... my 05 RS's trunk is light as hell, like a piece of cardboard, i dont think ill save much weight there by changing it to cf or anything else
Old Jan 4, 2006 | 08:36 AM
  #53
TForan's Avatar
Smile
I also have it posted in my sig, but my MR weighed in at 3400 with me in it at E-town. This included everything I drive with on a daily basis and 3/8-tank of gas. I usually have only 1/8th tank or less, but when I added 4gals of 116, it put me just under half unfortunately.
I don't necessarily doubt that someone could get the weight of a full interior Evo down to just below 3000; I just don't believe someone could do it to one that weighed 3400 initially when EMPTY, especially while retaining the stock sunroof. I don't see how you could shed 450lbs.
I'm guessing you weigh about 160 and you're around 5' 5" or the average size of a internet bully.
Old Jan 4, 2006 | 10:38 AM
  #54
Yaroslav's Avatar
Does someone know where to buy aluminum roof?
Old Jan 4, 2006 | 12:36 PM
  #55
mike1023's Avatar
can but one need to find one and then a shop who can but it on. which will cost an arm and a leg. as thats what i was told.
Old Jan 4, 2006 | 12:39 PM
  #56
Yaroslav's Avatar
ok..........
Old Jan 4, 2006 | 05:12 PM
  #57
Dropspeed's Avatar
This in my 05 GSR with no SSL package. full tank of gas, spare in and full interior.
Old Jan 4, 2006 | 06:02 PM
  #58
DragNRacing's Avatar
I weighed mine on a truck scale but it apparently was not accurate at lower weight readings. It reported 3150lbs with me in it and a quarter tank of gas.
Old Jan 4, 2006 | 06:13 PM
  #59
boostedwrx's Avatar
Best Motoring showed a clip about how had to use rivets to get the aluminum to mate with the steel. So if you find an al roof, good luck mounting it.
Old Jan 4, 2006 | 08:26 PM
  #60
Evo442's Avatar
Originally Posted by Alias
I thought I saw a post recently saying someone weighted the stock hood and it was like only 16lbs.
Nope; I weighed my stock 03 hood. 21lbs.
