can i run alky kit without tuneing?
Old Oct 11, 2005 | 05:58 PM
yesevo's Avatar
can i run the methanol without tuneing?
i just installed alky kit today. and i wanna try out to see if its working correctly..
but im afraid to do so, cause i havent got tune it yet for alky kit...
let me have some feedback please!
Old Oct 11, 2005 | 06:01 PM
fsugatorbait's Avatar
It will run ridiculously rich but will work till your tuned.
Old Oct 11, 2005 | 06:04 PM
Evil_1's Avatar
You can run it without tune but you'll be running very rich. Just look and see if the light under the word spray comes on. If it does it's working but you should check it according to SMC's specs. Rev car to like 3k and push the button on the controller to spray manually (car will choke and stumble like it's going to die, may also cause the check engine light to come on) and have someone look at the pressure gauge to see if it's pushing 100+psi after that, you're good to go for your tune.
Old Oct 11, 2005 | 06:08 PM
Precision Dyno's Avatar
Without a tune, try running just plain water injection. It will help cool the charge off conciderably.
The Alky will make it bog if running too rich. From the factory they run low 10:1 A/F ratio. You will just make it worse
Old Oct 11, 2005 | 06:38 PM
yesevo's Avatar
this is going to be 2nd tune by dynoflash..
running rich means i cant go wrong . i ll try out tomorrow, cant wait ~
one more Q,,,can i try 100% alcohol for just now? and switch to methanol later when im ready to get tune? thanks for the feedback
Old Oct 11, 2005 | 06:41 PM
Evil_1's Avatar
After you test it. Pull the fuse off on the alky kit and drive it to where ever you need to go to get it tune. Remember to plug the fuse back in for the tune.
Old Oct 11, 2005 | 06:48 PM
Evil_1's Avatar
I personally wouldn't do that. It's going to be alot of hassel to purge all the remaining alcohol that's left and fill with meth. If you were doing that, you'll have to detach the connection at the nozzle and push the manual button to purge it all out of the system. I don't know what the effects would be if you still have some alcohol left and add meth. It's better to stick to just one substance.
Old Oct 11, 2005 | 06:51 PM
By saying alky and methanol do you mean ethanol and then methanol
Old Oct 11, 2005 | 06:56 PM
Evil_1's Avatar
Alky is denature alcohol
Old Oct 11, 2005 | 07:01 PM
Denatured is ethanol with a percentage of methanol
Just out of curiousity why don't you run denatured?
Old Oct 11, 2005 | 07:16 PM
yesevo's Avatar
everyone here says methanol gives u most power ,,, but methanol is hard to get... so im thinking of getting alcohol from home depot, and test it out....
Old Oct 11, 2005 | 07:51 PM
yesevo's Avatar
can i safely turn up the boost from 21 to 25psi while running alcohol with no tune?
Old Oct 11, 2005 | 08:12 PM
Evil_1's Avatar
You are correct.
Old Oct 11, 2005 | 08:14 PM
Evil_1's Avatar
You're not going to benefit much from doing that without the tune. Be patient, you don't want to end up breaking something before the tune.
Old Oct 11, 2005 | 08:17 PM
joeymia's Avatar
your car will just run really rich and perform poorly.
