Radiator Questions?
Old Oct 12, 2005 | 05:12 PM
MetalGear214's Avatar
Radiator Questions?
I was installing a BOV on my evo then one of my little screwdriver fell in the space between the Fan Housing and the Radiator, I had to get a metal hanger to fish it out. I bent a lot of the metal mesh thing on the radiator on the process. My question , Is there a possibility that I put a hole on the radiator? should I be concern about the bent mesh things on the radiator? Will it affect cooling? thanks in advance for your help
Old Oct 12, 2005 | 05:16 PM
BuLocal's Avatar
You will probably know if there is a leak because you will see it or smell it, bending up the mesh wont make your radiator leak and probably wont hurt anything.
Old Oct 12, 2005 | 05:20 PM
If there was a hole, How bad will it leak? It will be under pressure right? so will the coolang spray or just leak slowly?
