good replacement battery (not mini!) for evo.. suggestions?
Old Oct 13, 2005 | 12:57 PM
cky3396's Avatar
since i know nothing about batteries and crank power, etc.. i figured id quiz you guys.
i need to replace the battery on my car, but im not sure which to get. i have a high out-put sound system so a mini battery seems out of the question.
any suggestions? and where i could get it?
Old Oct 13, 2005 | 01:01 PM
Aux.'s Avatar
Like what kinda problem are you running into ? What kinda system are you powering ? Basically what are your power requirements ? I know a little something about that kinda situation.
Old Oct 13, 2005 | 01:04 PM
Anarchy99's Avatar
Optima, Yellow or Red top.
Old Oct 13, 2005 | 01:07 PM
cky3396's Avatar
well i have no problem really, the stock battery ran my system fine. its just that the stock battery is now dead (drained and wont hold charge).. im just looking for a solid replacement
Old Oct 13, 2005 | 01:09 PM
tke_413's Avatar
Do you sit there and run the stereo constantly with the car on auxilary?
Old Oct 13, 2005 | 01:10 PM
badbrain's Avatar
I had a bad experience with Optima Yellow top on my Integra. After a year, it wouldn't hold a charge. It was too expensive to die that fast.
Old Oct 13, 2005 | 01:13 PM
Evo#1's Avatar
Get some Capacitors too, for every 1000 watts I would use atleast a 1 farad capacitor.. 2000 watts = 2 farad /minimum
this will take alot of load of the battery and alternator, you can never have to many capacitors plus they look cool in the trunk!!!!!
cky3396's Avatar
no... i hadnt driven the car for over a week and something drained it.
Old Oct 13, 2005 | 01:16 PM
cky3396's Avatar
i appreciate the advice on caps but i dont need any. i need a new battery... thanks though
Old Oct 13, 2005 | 01:17 PM
gofaster87's Avatar
Everyone I know and myself included use optima batterries for every vehicle. They are a gel cell battery and have quite a few options on size. Good warranty as well.
Old Oct 13, 2005 | 01:23 PM
Evo#1's Avatar
This is probable why you need capacitors, I have installed stereo equipment
for over 4 years, If your killing bateries, then there is to much load on the battery,
and your lucky you haven't blown an alternator
Old Oct 13, 2005 | 01:24 PM
cky3396's Avatar
well thats your opinion, and ive heard a lot of them.... i have a 300/4 JL and 500/1 to power my sub which i RARELY use.
Old Oct 13, 2005 | 01:26 PM
Evo#1's Avatar
well thats fine dude, I'm just trying to help you solve the problem
Old Oct 13, 2005 | 01:27 PM
cky3396's Avatar
i hear ya, thanks
Old Oct 13, 2005 | 01:50 PM
Aux.'s Avatar
Dude, i know what the "Cap guy" is saying . The only badthing about the cap is that it always needs tobe charged. You may notice that your battery has an excess amount of voltage being drawn from it if your lights dim when your sub hits. If it doesn't you might have an intermitently bad alternator. Because your alternator should be charging your battery just fine. I run one cap and i also have a a JL 10W6 , four Focal mids and some stock 6X9's. They run off a JL 800/5, i run this off a stock battery. So you should be fine , you might have some alternator issues.
