which would use more gas?
the thing is when at 2000 rpm, i have to press the gas a lot to get to 3000 rpm. but if im in a lower gear like 3000 rpm its easy to get up to 4000 rpm.
ok which would use more gas:
1. giving more throttle at lower rpms to get speeds up
2. giving less throtlle but at a higher rpm to get speeds up
what are threads coming to, my advice is drive with the lowest possible RPM and then downshift if you want to pick up speed.
