Works Rims
Old Oct 19, 2005 | 01:51 PM
djskyy's Avatar
Originally Posted by Aux.
Is it the 9 in width that is the problem with these or is it simething else. would 18X8.5 work ? Cause they have some 18X8.5's for some of these other rims !
the key to having it flush with your body panels is with the PERFECT OFFSET to clear your Brembos....
Old Oct 19, 2005 | 01:58 PM
djskyy's Avatar
Do they stick out of the wheel well any, are the flush like stock rims, or did you have to roll your fender ?
PS WHAT THE HELL IS OFFSET AND HOW DOES IT HELP THIS PROBLEM ??
no, to both questions....I run 245/40/18 tires....
Offset = is the distance from the inside surface of the dished center to the inside rim lip.
Aux.'s Avatar
Originally Posted by djskyy
I got some Enkei Bortex RPM2's in 18x9(35-offset, if I remember correctly)....perfect fitment on my MR....and it's dropped pretty low....no rubbing issues...
Old Oct 19, 2005 | 02:01 PM
Tsurara's Avatar
http://www.sportcompactcarweb.com/te...cc_wheelguide/
Read up
Aux.'s Avatar
So how do i figure out the correct offset ? Would fender rolling help me withthis situation ? Oh and when they say fender roll is that the inside of the car or the outside painted portion ?
Old Oct 19, 2005 | 02:04 PM
Tsurara's Avatar
Our stock offset is +35. You should use this as a starting point to selecting an offset, an improper offset might not clear the Brembos.
Old Oct 19, 2005 | 02:17 PM
Aux.'s Avatar
So after reading the offset guide would it be better to have less of an offset to push the rims deeper into the well but clear the caliper as well ?
dadriva's Avatar
Try Adam at Z1 Performance. He helped me a great deal with my wheels and they turned out great!
https://www.evolutionm.net/forums/sh...oly+lip+batman
Old Oct 19, 2005 | 08:23 PM
ChangBang's Avatar
I only have 245s and I get some rubbing in the right fender.
It all depends on the car. It's not that hard to find a place to roll you fenders. I did it myself with a metal pipe. Whatever works I guess.
evoevo10
For Sale - Wheels / Tires
13
Oct 10, 2012 04:05 AM
03evo**
May 10, 2008 12:19 AM
SoR
12
Jul 26, 2004 11:23 AM
kensuke
Mar 7, 2004 11:50 AM
csdriver
13
Oct 26, 2003 12:34 PM
