Best DP For 05'
Old Oct 22, 2005 | 03:54 PM
Eveolicious's Avatar
Whoa, Chewie, this isn't true at all. I haven't seen anyone with major problems attributed to an MBC on the stock turbo with no fuel compensation. We don't need injectors or a fuel pump on the stock turbo. Most of us just get a fuel pump when pushing more than pump gas boost (24+).
No, I wouldn't normally tell you go get a mail-in flash first, because you will have to get reflashed for other mods later, but since you are short on cash, I made a suggestion. You have to compromise. If you do the mbc+gauge, then you'll make some extra power, but won't require a tune to make it work. You can then get a flash later for even more power.
Well thats the only reason I have been holding off on the flash. So.. I guess I am going to go the mbc + gauge route. Sounds like a good enough b-day present.. heh.
Thanks for teh help.
Old Oct 22, 2005 | 03:58 PM
Johnny Boy's Avatar
Im using a tannabe
Old Oct 22, 2005 | 04:06 PM
05WhiteEVO8's Avatar
I have Megan DP and TP and have had no issues. If you are on a budget start from the back of the exhaust and work your way to the turbo. Megan TBE right now is like 550 shipped to your door, can't beat that.
Old Oct 22, 2005 | 04:15 PM
dr.mr's Avatar
I had the 2.75 in. HKS.
But now I love my 3" Buschur!
Old Oct 22, 2005 | 08:01 PM
staatz's Avatar
I'm rockin' the espelir...so..why not get that...lol..viturally it's 3"..it should be good
Old Oct 22, 2005 | 11:17 PM
Dr. SS's Avatar
the only mods i have are a boost gauge and a hallman pro set at 22 psi.
no fuel issues whatsoever. i run 93 oct.
Old Oct 22, 2005 | 11:29 PM
MaxR's Avatar
sheet, if money is an issue a test pipe will give you a very nice gain even on the stock exhaust. safer than an mbc, better gas mileage and it sounds stock.
Old Oct 23, 2005 | 02:32 AM
isaac@vishnu's Avatar
I have Vishnu 3" Standard DP w/ "highflow cat". A 3" Dp is a good size.
But if you're stressed on cash I'd go with a mail in flash. You'll be able to make more power and it'd be safe. You dont just want to "crank up boost." And if you're worried about havign to pay for more flashs for later mods, Vishnu offers free reflashing if you purchase the parts from us.
KTK
Old Oct 23, 2005 | 03:01 AM
lagcisco's Avatar
hks dp on my 05 gsr here, but its pretty close to the oil pan so i'm a bit concerned, going to get a heat shield and some gauges to monitor my engine when I do track days though
Old Oct 23, 2005 | 04:24 AM
DsmAwdTurbo's Avatar
Custom 3 inch turbo back from Pina MotorSports. The guy who built my exhaust is the best tig welder I have ever seen. www.pinamotorsports.com
Clears ACD as well.
Old Oct 23, 2005 | 07:58 AM
MuslimEvoFreak's Avatar
Greddy TI Titanium, DC sports downpipe, and Helix cat delete.......NO PROBLEMOS!!!
Old Oct 23, 2005 | 09:05 AM
Thx for the responses guys!
Old Oct 23, 2005 | 11:02 AM
by the way, I only have 2 total bends in my exhaust, one at the Dp ofcourse and then 2 very very very slight bends near the muffler and when i say slight I mean almost non exisistant.
Old Oct 23, 2005 | 01:17 PM
3vil3vo's Avatar
Which DP has a flex pipe in it? And fits the 05'?
Old Oct 24, 2005 | 01:19 PM
taenaive's Avatar
Originally Posted by taenaive
I just put back the stock catback today. I have a megan downpipe with HF cat. Megan downpipe doesn't fit 05 evo well. It doesn't clear the lower tie bar and touches the transfer case. So I put a perrin tie bar and exhaust wrap for the insulation. I drove my car today. It didn't seem to lose that much power. I will test it soon with my logger and let you all know the difference in power VS my Helix catback.
Ok, I just tested it today. I was surprised by the result. I lost about 20~25WHP !!!So, Here is an another example that having downpipe and HF doesn't really help if you have a stock catback.
