bad brakes or allignment?
Old Oct 23, 2005 | 08:22 PM
dave9172's Avatar
at interstate speeds(more noticebly), there is alot of shaking in the steering wheel when i gently press the brakes. its not as bad when i hit the brakes hard or when im at slower speeds. i have about 20000 miles on my 03 evo, never had the brakes changed but have had the allignment done at least once.
Old Oct 23, 2005 | 08:27 PM
Warrtalon's Avatar
Sounds like rotors warping - it's pretty common.
Old Oct 23, 2005 | 08:28 PM
evodave's Avatar
From: driving the 10 second beast in ohio or running lightmods.net
turn the rotors and get some new pads (not stock as they are overpriced)
Old Oct 23, 2005 | 08:33 PM
Jin4g63's Avatar
whats turn the rotors?
Old Oct 23, 2005 | 08:46 PM
dave9172's Avatar
ive had the brakes inspected before by a local shop, the mechanic at the shop told me the rotors on the evo coulnt be turned due to their design. is this not true?
Old Oct 23, 2005 | 09:16 PM
BSREVOLUTION's Avatar
false, they can be turned.
Old Oct 23, 2005 | 09:43 PM
Jin4g63's Avatar
okey nobody has answered my question
Old Oct 23, 2005 | 09:44 PM
Nad1370's Avatar
Cut mine 3X already.
I have 33K miles.
Old Oct 23, 2005 | 09:51 PM
Nad1370's Avatar
It's when you take your car to a shop and they will cut your brake rotors so it will have no run-out in them.
They put your rotors in a brake lathe or just cut them while in the hub of your car.
Old Oct 23, 2005 | 10:16 PM
dave9172's Avatar
is this similar to having them turned, or how is this different(cutting).
Old Oct 31, 2005 | 05:50 AM
dave9172's Avatar
again, how is the cutting different than turning, will any shop due this, as i mentioned before the one shop i went to told me the rotors on the evo couldnt even be turned.
Old Oct 31, 2005 | 07:24 AM
Jim_Patterson's Avatar
Definatly warped rotors
Old Oct 31, 2005 | 07:43 AM
Aux.'s Avatar
There is no difference dude. "Cutting", "Turning", and "Resurfacing" are all the same thing . What they do is check how deep (if any) the grooves are in you rotor with a micrometer (refered to as mike cheking your rotors for allowable limits). Then the mechanic binds them in a vice that spins and they take a big metal rod and slowly scrape layers off the top of the surface of the rotors till the groove or deficency is gone, hence the names cutting, resurfacing , or turning. We good ?
Old Oct 31, 2005 | 08:50 AM
FinsNCanes's Avatar
May not be your rotors. I know I had the same problem and it was cause of my tires. 4 days later one blew out so I guess they were right.
Old Oct 31, 2005 | 09:55 PM
dave9172's Avatar
thank you!
